[Check_mk (english)] mklivestatus/Nagios 4 - File Not Found when loading Module
Good Evening,
Trying to load the mk-livestatus module into a fresh install of Nagios 4.0.0.0beta4 but I'm getting the following error:
[1378844599] Nagios 4.0.0beta4 starting... (PID=28622)
[1378844599] Local time is Tue Sep 10 21:23:19 BST 2013
[1378844599] LOG VERSION: 2.0
[1378844599] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1378844599] qh: core query handler registered
[1378844599] nerd: Channel hostchecks registered successfully
[1378844599] nerd: Channel servicechecks registered successfully
[1378844599] nerd: Channel opathchecks registered successfully
[1378844599] nerd: Fully initialized and ready to rock!
[1378844599] wproc: Successfully registered manager as @wproc with query handler
[1378844600] wproc: Registry request: name=Core Worker 28625;pid=28625
[1378844600] wproc: Registry request: name=Core Worker 28623;pid=28623
[1378844600] wproc: Registry request: name=Core Worker 28626;pid=28626
[1378844600] wproc: Registry request: name=Core Worker 28624;pid=28624
[1378844600] Error: Could not load module '/usr/local/lib/mk-livestatus/livestatus.o' -> file not found
[1378844600] Error: Failed to load module '/usr/local/lib/mk-livestatus/livestatus.o'.
[1378844600] Error: Module loading failed. Aborting.
Didn't get any errors during compliation or install. I can see the files there and appears that it should be accessible from the 'nagios' user:
-rwxr-xr-x 1 root staff 516600 Sep 10 21:17 /usr/local/lib/mk-livestatus/livestatus.o
Trying to install it on Debian 7.1:
Linux 3.2.0-4-amd64 #1 SMP Debian 3.2.46-1+deb7u1 x86_64 GNU/Linux
Frustratingly whilst testing, I successfully had this installed my Raspberry PI with Nagios 3 but wanted it on something a bit more powerful. I also heard that the livestatus module isn't compatible with Nagios 4 so wanted to confirm if this was the case.
Thanks in advance for your help.
Lee
Evening, any thoughts on this?
Or is it simply that MKLiveStatus isn't yet compatible with Nagios 4.
Thanks
Lee
----- Original Message -----
To: "checkmk-en@lists.mathias-kettner.de" <checkmk-en@lists.mathias-kettner.de>
Cc:
Sent: Tuesday, 10 September 2013, 21:28
Subject: [Check_mk (english)] mklivestatus/Nagios 4 - File Not Found when loading Module
Good Evening,
Lee
checkmk-en mailing list
I am also curious if check_mk is going to support Nagios 4? And if we do, does that mean check_mk doesn’t have to have its own queue worker anymore, since Nagios 4 is already implemented with asynchronous processes?
thanks,
Henry
Or is it simply that MKLiveStatus isn’t yet compatible with Nagios 4.
Thanks
Lee
To: “checkmk-en@lists.mathias-kettner.decheckmk-en@lists.mathias-kettner.de
Cc:
Good Evening,
Trying to load the mk-livestatus module into a fresh install of Nagios 4.0.0.0beta4 but I’m getting the following error:
[1378844599] Nagios 4.0.0beta4 starting… (PID=28622)
[1378844599] qh: Socket ‘/usr/local/nagios/var/rw/nagios.qh’ successfully initialized
[1378844600] Error: Could not load module ‘/usr/local/lib/mk-livestatus/livestatus.o’ → file not found
[1378844600] Error: Failed to load module ‘/usr/local/lib/mk-livestatus/livestatus.o’.
Didn’t get any errors during compliation or install. I can see the files there and appears that it should be accessible from the ‘nagios’ user:
Frustratingly whilst testing, I successfully had this installed my Raspberry PI with Nagios 3 but wanted it on something a bit more powerful. I also heard that the livestatus module isn’t compatible with Nagios 4 so wanted to confirm if this was the case.
Lee
If you want to try Nagios4 then you have two possible test variants.
1 - get the nagios4 and livestatus source from op5 GIT repo (livestatus needs to be changed to be compatible with nagios4) - http://git.op5.org/git/?p=nagios/livestatus.git
2 - get a complete omd with nagios4 and icinga2 made by Sven Nierlein at https://github.com/ConSol/omd/tree/newcores
Happy testing :slight_smile:
br
Andreas
2013/9/20 Henry Huang red.rain.seven@gmail.com
thanks,
Henry
Thanks
Lee
Cc:
Good Evening,
Lee
Thanks Andreas, I’ll give those options a go.
To: Henry Huang red.rain.seven@gmail.com
Cc: Lee Wilson leefm40@yahoo.co.uk; “checkmk-en@lists.mathias-kettner.decheckmk-en@lists.mathias-kettner.de
Sent: Friday, 20 September 2013, 9:21
Subject: Re: [Check_mk (english)] mklivestatus/Nagios 4 - File Not Found when loading Module
br
Andreas
thanks,
Henry
Thanks
Lee
Cc:
Good Evening,
Lee
