This e-mail is confidential, may be legally privileged, and is for the intended recipient only. Access, disclosure, copying and distribution or reliance on any
of it by anyone else is prohibited and may be a criminal offence. Please delete if obtained in error and e-mail confirmation to the sender.
This message has been scanned for viruses and
dangerous content by MailScanner, and is
cifs is excluded from df check in linux agent. You could search/grep
for "excludefs" and change the line not to exclude cifs. This way you
would get all cifs mounts automatically inventorized (for all hosts
running this customized agent).
Or you take the df part of the agent and create your own local check
or plugin to provide cifs shares. All hosts providing cifs shares must
have this plugin/local check.
Personally I'd prefer the plugin way - just take the whole df-part of
the agent, customize it to output ONLY cifs and put this plugin to all
appropriate hosts in the plugins folder of the agent. Doesn't matter
if the df section is provided more than once - cmk will use "all"
sections.
HTH,
Marcel
2013/12/10 Philip Parsons <pparsons@techeez.com>:
I should have added using wato to do this ? I cannot seem to find the
option
[mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Philip
Parsons
Sent: December-10-13 11:33 AM
Subject: [Check_mk (english)] Monitor CIFS share
Does anyone have a way to monitor that a CIFS share is mounted on a linux
server ?
Thank you.
Philip Parsons
IT and Telecommunication Specialist
Techeez IT Consulting
250-818-2879
Skype ID: techeez
www.techeez.com "Making IT easy"
IMPORTANT NOTICE
reliance on any of it by anyone else is prohibited and may be a criminal
sender.
believed to be clean.
sections.
HTH,
Marcel
option
Parsons
server ?
Thank you.
Philip Parsons
250-818-2879
Skype ID: techeez
IMPORTANT NOTICE
sender.
sections.
HTH,
Marcel
option
Parsons
server ?
Thank you.
Philip Parsons
250-818-2879
Skype ID: techeez
IMPORTANT NOTICE
sender.
I change this in the client section for DF on the client and when I do the cmk -d host name the mount show up the bottom 3 are the ones I want. But when I look at the services in wato for the client the bottom 3 do not show up ??
sections.
HTH,
Marcel
option
Parsons
server ?
Thank you.
Philip Parsons
250-818-2879
Skype ID: techeez
IMPORTANT NOTICE
sender.
...change that line and it should work - just tested this myself.
Regards,
Marcel
2013/12/11 Philip Parsons <pparsons@techeez.com>:
sections.
HTH,
Marcel
option
Parsons
server ?
Thank you.
Philip Parsons
250-818-2879
Skype ID: techeez
IMPORTANT NOTICE
sender.
Regards,
Marcel
sections.
HTH,
Marcel
option
Parsons
server ?
Thank you.
Philip Parsons
250-818-2879
Skype ID: techeez
IMPORTANT NOTICE
sender.
