[Check_mk (english)] monitor HTTPS
Hi!
We are having some trouble to monitor HTTPS enabled websites and have tried many different combinations of options to no avail. The error reported back is “ Cannot
make SSL connection” and nothing more.
Service check command
check_mk_active-http!’-H’ ‘host.domain.se’ ‘-u’ ‘/’ ‘–ssl’ ‘–sni’ ‘–onredirect=follow’ ‘-d’ ‘HTTP/1.1 200 OK’
We are running version 1.5.0p12 on a Debian 7.11 OS.
We hope you have any suggestions on how to resolve this issue and if you need more information just ask.
Best regards
Tony Bohlin
Direkt: 0470-77 99 91 • tony.bohlin@officeitpartner.se
Office IT-Partner Växjö/Ljungby
Södra Vallviksvägen 8, 352 51 Växjö • 0470-77 99 99
Org.nr 556307–2627
www.officeitpartner.se/vaxjo
Din integritet är viktig för oss. Läs vår integritetspolicy här.
Hey Tony,
Did you select the option of “Use SSL/HTTPS for the connection”, If yes, which option have you selected in that ?
If no, please enable this option and check.
Thanks & Regards,
Praveen.
On Wed, Apr 24, 2019 at 2:53 PM Tony Bohlin via checkmk-en checkmk-en@lists.mathias-kettner.de wrote:
Hi!
check_mk_active-http!‘-H’ ‘host.domain.se’ ‘-u’ ‘/’ ‘–ssl’ ‘–sni’ ‘–onredirect=follow’ ‘-d’ ‘HTTP/1.1 200 OK’
Best regards
Tony Bohlin
Org.nr 556307–2627
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
Hi Praveen,
I got it to work now if I don’t use redirect and instead use the redirected uri.
check_mk_active-http!‘-H’ ‘host.domain.se’ ‘-u’ ‘/login?ReturnUrl=/’ ‘–ssl’ ‘–sni’ ‘-e’ ‘HTTP/1.1 200 OK’
If I use redirect it follows the redirect to the first “301” but then errors at “302” where I should redirect and get “HTTP/1.1 200 OK”
Regards Tony
Hey Tony,
Thanks & Regards,
Praveen.
Hi!
check_mk_active-http!‘-H’ 'host.domain.se
Best regards
Tony Bohlin
Org.nr 556307–2627
* Din
integritet är viktig för oss. Läs vår integritetspolicy här.*
Hi Tony,
which SSL/TLS version do your https sites use? It may be this version is not supported in Debian7 - and because if that those are also not supported in CMK at Debian7.
You could test this at a Debian9 system by installing CMK there and just configure one of the failing hosts with the HTTP check…
HTH,
Marcel
Tony Bohlin via checkmk-en checkmk-en@lists.mathias-kettner.de schrieb am Mi., 24. Apr. 2019, 14:53:
Hi!
Best regards
Tony Bohlin
cid:image001.png@01D3F69A.C91CA310
Org.nr 556307–2627
cid:image004.png@01D4566B.C37B63C0cid:image006.png@01D4566B.C37B63C0cid:image008.png@01D4566B.C37B63C0cid:image010.png@01D4566B.C37B63C0cid:image012.png@01D4566B.C37B63C0
cid:image007.jpg@01D492C3.2C3CFF20
Hi Marcel,
I managed to get it to work, if i leave the redirect out , and set the uri to the last address in the redirect chain.
check_mk_active-http!‘-H’ ‘host.domain.se’ ‘-u’ ‘/login?ReturnUrl=/’ ‘–ssl’ ‘–sni’ ‘-e’ ‘HTTP/1.1 200 OK’‘HTTP/1.1
200 OK’
The redirect goes like this
http://host.domain.se >
301 (Moved Permanently) >
https://host.domain.se
> 302 (found) >
https://host.domain.se/login?ReturnUrl=/
and I get error
“Invalid HTTP response received from host on port 443: HTTP/1.1 302 Found”
Regards
Tony
Hi Tony,
HTH,
Marcel
Hi!
Best regards
Tony Bohlin
Org.nr 556307–2627
* Din
Okay, unexpected, but if this works…
We don’t have our hands on this check_http, it’s taken from monitoring-plugins.org
BR,
Marcel
Tony Bohlin tony.bohlin@officeitpartner.se schrieb am Mi., 24. Apr. 2019, 18:12:
Hi Marcel,
check_mk_active-http!‘-H’ 'host.domain.se ’ ‘-u’ ‘/login?ReturnUrl=/’ ‘–ssl’ ‘–sni’ ‘-e’ ‘HTTP/1.1 200 OK’‘HTTP/1.1
200 OK’
> 302 (found) >
and I get error
Regards
Tony
Sent: den 24 april 2019 17:19
To: Tony Bohlin tony.bohlin@officeitpartner.se
Cc: checkmk-en@lists.mathias-kettner.de checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] monitor HTTPS
Hi Tony,
HTH,
Marcel
Hi!
Best regards
Tony Bohlin
Org.nr 556307–2627
* Din
Hi
Why are you using -e option of check_http here ?
I think you can't use -e and --onredirect together
Use -s (string) or -r (regex) instead if you want to check content.
Try check_http --help.
Regards
Stéphane
Le 24/04/2019 à 16:17, Tony Bohlin via checkmk-en a écrit :
Hi Praveen,
check_mk_active-http!'-H' 'host.domain.se' '-u' '/login?ReturnUrl=/' '--ssl' '--sni' '-e' 'HTTP/1.1 200 OK'
Regards Tony
*From:*Praveen Kumar Velpula <praveen.velpula@gmail.com>
*Sent:* den 24 april 2019 15:15
*To:* Tony Bohlin <tony.bohlin@officeitpartner.se>
*Cc:* checkmk-en@lists.mathias-kettner.de
*Subject:* Re: [Check_mk (english)] monitor HTTPS
Hey Tony,
Did you select the option of "Use SSL/HTTPS for the connection", If yes, which option have you selected in that ?
Thanks & Regards,
Praveen.
On Wed, Apr 24, 2019 at 2:53 PM Tony Bohlin via checkmk-en <checkmk-en@lists.mathias-kettner.de <mailto:checkmk-en@lists.mathias-kettner.de>> wrote:
    Hi!
    We are having some trouble to monitor HTTPS enabled websites and have tried many different combinations of options to no avail. The error reported back is “Cannot make SSL connection” and nothing more.
    Service check command check_mk_active-http!'-H' 'host.domain.se <https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fhost.domain.se&data=02|01|tony.bohlin%40officeitpartner.se|b8ba1034a260411e387d08d6c8b6d1d5|bf98cdd615494b42a71580afda28432f|0|0|636917084871852156&sdata=mZsRxeBMERan7LFG%2F%2F1yggfBftF1aFNGXZJTeKsYXxo%3D&reserved=0&gt;&#39; '-u' '/' '--ssl' '--sni' '--onredirect=follow' '-d' 'HTTP/1.1 200 OK'
    *Best regards*
    *Tony Bohlin*
