Nevermind. Not sure what I did differently, but it is working now.
Sr. Network Administrator
Keystone Automotive Operations, Inc.
From: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Lance Tost
Sent: Monday, August 04, 2014 3:09 PM
To: Paul - Monitoring
Subject: Re: [Check_mk (english)] Monitoring Linux logs
Cmk version 1.2.4p5
Logwatch.cfg:
cat logwatch.cfg
/var/log/messages
W foobar
/opt/Linoma_Software/GoAnywhere_Services/userdata/logs/gaservices.log
C Failed to start proxy server
W Proxy server .* started
So I do a logger –pdaemon.info foobar which syslogs foobar to my /var/log/messages file. If I run the plugin manually or the agent manually on the host, it works:
[[[/var/log/messages]]]
W Aug 4 15:03:15 : foobar
[[[/opt/Linoma_Software/GoAnywhere_Services/userdata/logs/gaservices.log]]]
However, I cannot get the service to show up when inventorying the server.
Thanks,
Lance Tost
From: Paul - Monitoring [mailto:paulmonitoring@gmail.com]
Sent: Monday, August 04, 2014 1:37 PM
To: Lance Tost
Cc: Bill Jacqmein; Pawel Grzesik; checkmk-en@lists.mathias-kettner.de
Which version of check_mk do you run? Do you have the logwatch check on your monitoring host? Please provide your logwatch cfg file also for initial troubleshooting.
On Aug 4, 2014, at 13:24, Lance Tost Lance.Tost@key-stone.com wrote:
These seem more like solutions to “dig into logs” for troubleshooting. I want something simple that will raise an alert in Check_Mk if a specific string is found in a logfile. I’m not looking to correlate logs, etc.
Thanks,
Lance Tost
Sent: Thursday, July 31, 2014 4:25 PM
To: Pawel Grzesik
Cc: Lance Tost; checkmk-en@lists.mathias-kettner.de
I will second the logstash (http://logstash.net/) and add on Elastic Search and Kibana (http://www.elasticsearch.org/overview/kibana/) to slice and dice the logs as needed.
On Thu, Jul 31, 2014 at 3:50 PM, Pawel Grzesik pawel.grzesik@brainstorm.co.uk wrote:
On 31 Jul 2014, at 20:31, Lance Tost Lance.Tost@key-stone.com wrote:
What is the recommended way for monitoring Linux logs?
Mk_logwatch plugin?
Point all syslogs at Nagios server and use the Event Monitor?
What about for non-syslog logs (ie., applications that log to their own dir)? Can you use a mix of the above to methods?
I’m trying to use mk_logwatch, but cannot get anything to show up in inventory. I’ve created a logwatch.cfg and tested it locally by manually running logwatch –d. It reports the logs it’s watching… but nothing in inventory. What am I missing?
Thanks,
Lance
I will choose logstash
Thanks,
Pawel
checkmk-en mailing list
Please consider the environment before printing
