We use CheckMK to monitor storage size and a few of the other default checks.
I want to set it up to monitor if Asterisk, Hylafax, CSF, and a few other services we have running are running or stopped on a cluster of servers.
I’ve seen a plugin for Nagios: http://www.hylafax.org/content/Monitor_your_fax_queue_with_Nagios
I have not tried putting it in # /usr/lib/check_mk_agent/plugins
I’ve also read your guide to setting up new notifications:https://mathias-kettner.com/checkmk_flexible_notifications.html
Can you lend some insight on setting up checks like this?
Thanks.
Hi Cory,
We recently set up some monitoring of Asterisk using an agent plugin
& check. I’ll grab the components and throw them up on github
shortly.
Cheers,
Chris
a few of the other default checks.�
I�ve seen a plugin for Nagios:
I�ve also read your guide to setting up new
notifications:
checks like this?
Thanks.
checkmk-en mailing list
We�ll meet in Munich for the 2nd Check_MK Conference!
Book your place now and be part of it.
October 18th-20th, 2015
-- Chris Rosenhain Linux Systems Engineer
NetCraft Australia Pty Ltd
Phone +61 8 8338 0888
checkmk-en@lists.mathias-kettner.dehttp://lists.mathias-kettner.de/mailman/listinfo/checkmk-enhttp://mathias-kettner.com/conferencechris@netcraft.com.auhttp://www.netcraft.com.au/
Hi Cory,
If your nodes are monitored using the check_mk agent you can monitor processes, too:
https://mathias-kettner.de/checkmk_check_ps.html
https://mathias-kettner.de/checkmk_check_ps.perf.html
Clusters can also be defined:
https://mathias-kettner.de/checkmk_clusters.html
HTH,
Marcel
Cory Sanders cory@securecloudsolutions.com schrieb am Do., 17. Sep. 2015 07:16:
Thanks.
We’ll meet in Munich for the 2nd Check_MK Conference!
