[Check_mk (english)] Monitoring specific deployments in kubernetes
Group,
After some help from the group, I’ve got check mk talking to my kubernetes cluster. Thanks!
However, now I’m trying to figure out how to monitor a specific deployment. I’d like to see how many pods, how much memory, how much CPU (absolute or %).
Do I need to modify the special agent to get that detail of information? I’d be happy to contribute it back.
Thanks,
Joe
“There are only two industries that refer to their customers as ‘users’.” - Edward Tufte
Zitat von Bothari <bothari@gmail.com>:
Group,
After some help from the group, I've got check mk talking to my kubernetes
cluster. Thanks!
However, now I'm trying to figure out how to monitor a specific deployment.
I'd like to see how many pods, how much memory, how much CPU (absolute or
I'd be happy to contribute it back.
Thanks,
Joe
I think we will see more informations in the checks when Version 1.6 is out.
You know grafana? This solutions shows you tons of informations and graphs.
Ralf
Group,
cluster. Thanks!
some questions
1)
CRE or CEE Version of check-mk?
The CEE version has a full agent-setup-management.
2)
You need a signature for the initial setup or permanent?
3)
How do you manage setup-packages?
Ralf
We’re using CRE
These environments will be permenent
Currently we install kubernetes with RKE, just because there is some rancher 1.0 in a nearby group.
