i tried it too today. Got it working.
There is one important step missing.
You have to copy from the site where you install the mkp the mtr script
from /opt/omd/site/local/share/.../mtr (as i recall from my mind)
Then, the check_mk-agent will pick up the mtr and the mtr.cfg (/etc/check_mk/mtr.cfg)
on that host.
After that, that plugin is really are amazing. Once you understand, what you
now have in your hands...
The config is not so tricky at all, when you know all the parameters:
# Mtr Check_MK configuration
# NOTE: your MTR report shouldn’t take longer than 15 minutes
# [DEFAULTS]
# type=icmp # icmp, tcp or udp
# count=10 # number of pings per mtr report
# force_ipv4=0 # force ipv4, exclusive with force_ipv6
# force_ipv6=0 # force ipv6, exclusive with force_ipv4
# size=64 # packet size
# time=0 # minimum time between runs, 0 / default means run if mtr doesn’t run anymore
# port=80 # UDP/TCP port to connect to
# dns=0 # Use DNS resolution to lookup addresses
# address= # Bind to source address
# interval= # time MTR waits between sending pings
# timeout= # ping Timeout, see mtr man page
The reports you got then, have some time to understand what you get.
But, it works mostly good with Ubuntu/Debian flavors.
With SLES11, older then SP3, not so much....
Mostly because the syntax of the mtr seems different....
HTH
Timo
to: /usr/lib/check_mk_agent/plugins/mtr
----- Original Message -----
I'm trying to get the following mtr plugin to work:
Check_MK plugin: MTR for pretty ping graphs « BenV's notes
I followed config steps and i see the package installed with the
check_mk -vP list command.
But when i do an inventory scan of the localhost i dont see the mtr
service L
Met vriendelijk groet,
<http://www.oib4u.nl/>
Sander van der Laan
Email
s.vanderlaan@oib4u.nl <mailto:s.vanderlaan@oib4u.nl>
Telefoon
+31(0)570 546587
Fax
+31(0)570 546541
Bezoekadres
Zweedsestraat 8A28
7418 BG Deventer
checkmk-en mailing list
Beste Grüße
Timo Scheller
Timo Scheller
Hochschul-IT-Zentrum (HIZ)
Universität des Saarlandes
Campus E1_2 (Büro 0.12)
D-66123 Saarbrücken
Tel: +4968130270626
Fax: +496813024462
Tel-HR: +49 (0)681/302-70626
Fax-HR: +49 (0)681/302-4462
E-Mail: timo.scheller@hiz-saarland.de
Internet: http://www.hiz-saarland.de
