I've gone through and checked what the modproxy instructions say and still getting an error on the hover popups.
I'm pretty sure I got all the distributed monitoring set up as it should be. Everything else seems to be working at least.
Sockets are set to:
tcp:site1:6558
tcp:site2:6558
URL prefix:
http://server1/site1/
http://server2/site2/
Multisite URL of remote site:
http://server1/site1/check_mk/
http://server2/site2/check_mk/
In /etc/httpd/conf.d/multisite_proxy.conf:
<Location /site1>
RewriteEngine On
RewriteRule ^/.+/site1/(.*) http://server1/site1/$1 [P]
</Location>
<Location /site2>
RewriteEngine On
RewriteRule ^/.+/site2/(.*) http://server2/site2/$1 [P]
</Location>
Both sites and the main server have the same /opt/omd/sites/<site>/etc/auth.secret and auth.serials
A filtered list of LDAP users are being pulled from our FreeIPA servers, authentication works using that with no issues. Well one small issue, if I start firefox, pull up the main site and login, then try to go to the services view for a system on one of the slave servers I have to login there also, after that the login is remembered. I think that's the way it normally works but if I can avoid the additional logins to slave systems that would be nice. If I could get check_mk to use a kerberos TGT for login that would really nice.
I've checked the AuthName in /etc/httpd/conf.d/auth.conf and all three systems are the same.
This is the two log entries I see in the slave server apache log when I hover over the graph icon from the master site web UI:
<My IP> - - [12/Jul/2016:09:10:02 -0500] "GET /sit2/pnp4nagios/index.php/popup?host=host1&srv=_HOST_ HTTP/1.1" 302 - "http://master/mainsite/check_mk/view.py?view_name=allhosts" "Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:47.0) Gecko/20100101 Firefox/47.0"
<My IP> - - [12/Jul/2016:09:10:02 -0500] "GET /site2/check_mk/login.py?_origtarget=/site2/pnp4nagios/index.php/popup?host=host1&srv=_HOST_ HTTP/1.1" 200 2202 "http://master/mainsite/check_mk/view.py?view_name=allhosts" "Mozilla/5.0 (X11; Fedora; Linux x86_64; rv:47.0) Gecko/20100101 Firefox/47.0"
I'm probably missing one little step in the setup but I'm having a heck of a time finding that one step.
On 07/11/2016 11:46 AM, Paul Bongers wrote:
Hi Stephen,
If you want to have the PNP graphs working in a distributed setup, you
need to set up mod_proxy on your master site to connect to your remote
sites.
This is also on the website:
http://mathias-kettner.com/checkmk_multisite_modproxy.html
HTH,
Paul
On 11/07/16 17:47, Stephen Berg (Contractor) wrote:
I've had a Nagios then check_mk then omd setup for a few years now.
Trying to further migrate to using WATO and the distributed monitoring
on one master and seven slave setups. I've run into a glitch that I
guess I just haven't wrapped my brain around the correct sequence of
steps yet.
Master is setup, two slave set up so far, everything seems to be
working except the pnp4nagios hover popups for graphs when I view a
host that is monitored on one of the slaves. If I click on the graph
icon I see the graphs for that service.
Is this something to do with the auth.secret file? I can't seem to
find documentation on what I should be doing with that file on the
master or slave servers.
checkmk-en mailing list
Stephen Berg
Systems Administrator
NRL Code: 7320
Office: 228-688-5738
stephen.berg.ctr@nrlssc.navy.mil
