Livestatus problem: 400: Table 'services' has no column
'service_pnpgraph_present'
Only one host - localhost - is in my default nagios configuration.
For clicking on Hosts at Tactical overview, the message is:
Livestatus problem: 400: Table 'hosts' has no column 'host_pnpgraph_present'
PNP4Nagios is installed and it seems working but here is something:
cl0-dhcp:/var/lib/nagios #
/usr/local/pnp4nagios/libexec/verify_pnp_config.pl -b /usr/lib/nagios
-c /etc/nagios/nagios.cfg -B /usr/sbin/nagios -e -m sync
Check Nagios/Icinga/PNP integration, v0.1.28
[I] option -e
[I] OS: Welcome to openSUSE 11.3 "Teal" - Kernel ().
[I] Perl: 5.012001
[I] Package Manager: /bin/rpm
[I] Package: "nagios-3.2.3-21.1.i586"
[I] Package: "php5-5.3.5-51.2.i586"
[I] Package: "dejavu-2.30-4.1.noarch"
[I] install_opts: -o nagios -g nagios
[I] PNP-version: 0.6.11
[I] using Nagios basedir "/usr/lib/nagios"
[I] using Nagios config "/etc/nagios/nagios.cfg"
[I] using Nagios binary "/usr/sbin/nagios"
[I] PNP mode: "sync"
[I] Nagios info: Nagios Core 3.2.3
[A] verifying Nagios config
[A] processing "/etc/nagios/nagios.cfg"
[I] nagios_user=nagios
[I] nagios_group=www
[A] checking RRDtool (/usr/bin/rrdtool)
[I] RRDtool: RRDtool 1.4.3
[I] RRDs perl module installed
[A] processing "/etc/nagios/resource.cfg"
[I] using "/var/lib/nagios/objects.cache" entries
[A] processing "/usr/local/pnp4nagios/etc/process_perfdata.cfg"
[A] processing "/usr/local/pnp4nagios/etc/config.php"
[E] "$conf['livestatus_socket']" is not a valid option
[A] checking of RRDpath "/usr/local/pnp4nagios/var/perfdata"
[I] 2 dir(s) with a total of 14 rrd file(s)
Errors found. Please check the settings and have a look at the documentation.
TIA,
Ruzsi
-%<-- CUT
Thats not an PNP issue!
Your Multisite Version is newer then your Livestatus Module!
service_pnpgraph_present is available sind 1.1.9i5 IMHO
Joerg
please update your Livestatus to 1.1.9i5.
Mathias
ยทยทยท
Am 30.01.2011 14:33, schrieb Ruzsinszky Attila:
[I] option -e
[I] Perl: 5.012001
TIA,
Ruzsi
checkmk-en mailing list
