[Check_mk (english)] Multisite to a server with more than one site
Not sure what's going on here. From a brand new site on my master server I'm trying to set up a multisite connection to a slave server that has two sites defined and functioning.
In the "URL prefix" I've defined the site I want to target but I seem to get data from the other site on that slave server. I've set it to "Connect via TCP", given it the host and 6557 for the port. I'm not sure by any means but shouldn't the port be different for one site as compared to the other? I created both sites using default values, one a year or three ago, the second site just created a couple days ago. I don't recall seeing any option for the unixcat port when I created the site.
Stephen Berg
Systems Administrator
NRL Code: 7320
Office: 228-688-5738
stephen.berg.ctr@nrlssc.navy.mil
I would login to the target site(s) and run 'omd config <site>', then go to 'Distributed Monitoring' and get the value of LIVESTATUS_TCP_PORT and use that to configure the
connection on the master.
That's the trick I needed! I put the new site on a different port. Is that the preferred way to do things? Or can you have multiple sites on the same port?
Stephen Berg
NRL Code: 7320
You cannot have multiple sites on the same port.
Unfortunately there is no automatism yet to detect a free port for the
livestatus tcp port.
Regards
the same port?
Robert Sander
Heinlein Support GmbH
Tel: 030 / 405051-43
Fax: 030 / 405051-19
Zwangsangaben lt. §35a GmbHG:
HRB 93818 B / Amtsgericht Berlin-Charlottenburg,
Geschäftsführer: Peer Heinlein -- Sitz: Berlin
