Hi:
After successful installation of CentOS 6.4, Nagios 4.0.1 core, Centreon 2.4.5 I need to install Nagvis and mk-livestatus as a backend broker.
Following instructions on author’s site, the installation is fairly simple, but, after restart of Nagios I have these messages in nagios.log:
[1382843320] Error: Could not load module ‘/usr/local/lib/mk-livestatus/livestatus.o’ → /usr/local/lib/mk-livestatus/livestatus.o: undefined symbol: last_command_check
[1382843320] Error: Failed to load module ‘/usr/local/lib/mk-livestatus/livestatus.o’.
[1382843320] Error: Module loading failed. Aborting.
I found that other people have the same problem too:
http://tracker.nagios.org/view.php?id=509
http://www.holediscover.com/install-mklivestatus-on-centoos/
4. Error with Nagios core 4.0.1
Has anyone seen something like this?
Hi Haris,
sometimes one could think about a "search archive first, ask later if
necessary" policy, like used in most forums, for mailinglists, too...
http://www.mail-archive.com/checkmk-en@lists.mathias-kettner.de/msg09253.html
http://www.mail-archive.com/checkmk-en@lists.mathias-kettner.de/msg09574.html
HTH,
Marcel
2013/11/22 Haris Saračević <haris.saracevic@gmail.com>:
Hi:
Following instructions on author's site, the installation is fairly simple,
‘/usr/local/lib/mk-livestatus/livestatus.o’ ->
last_command_check
Nagios Enterprises · GitHub
checkmk-en mailing list
Hello Marcel,
Thanks for your answer, sorry to waste your time!
haris
On Fri, Nov 22, 2013 at 11:36 AM, Marcel Schulte <schulte.marcel@gmail.com>wrote:
Hi Haris,
HTH,
Marcel
> Hi:
simple,
>> '/usr/local/lib/mk-livestatus/livestatus.o' ->
>> last_command_check
>> '/usr/local/lib/mk-livestatus/livestatus.o'.
> _______________________________________________
> http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en
