I know each plugin is individually supported but I'm struggling to
figure out how to enable the additional stats on hosts?
I've installed the plugin but I'm not seeing the availability of the
additional agent nor additional checks on any of the hosts after scanning.
Am I missing something on activating the plugin?
Thanks
Andrew
I'm facing the same issue ! I'm a newbie and I begin to loose my hair searching for that kind of information ;o)
Can someone give us a hint ?
Thank you,
Eric.
-----Original Message-----
From: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On Behalf Of Andrew Speer
Sent: vendredi 22 avril 2016 16:29
Subject: [Check_mk (english)] NFS perfromance data plugin - nfsperf-1.0.1.mkp
I know each plugin is individually supported but I'm struggling to figure out how to enable the additional stats on hosts?
I've installed the plugin but I'm not seeing the availability of the additional agent nor additional checks on any of the hosts after scanning.
Thanks
Andrew
checkmk-en mailing list
Hi Andrew, Eric,
I’m not using this MKP but as with all packages which include plugins:
You have to copy the plugin (not the check file!) to the agent’s filesystem, make sure it’s executable and should get what you want. You can find the right agent folder as plugin directory in the first 10-20 lines of agent output (“cmk -d AGENTHOST | head -20”).
Did you add the plugin to the right folder at agent side?
Regards,
Marcel
Eric Lecocq Eric.Lecocq@prodata-systems.be schrieb am Fr., 27. Mai 2016 16:18:
I’m facing the same issue ! I’m a newbie and I begin to loose my hair searching for that kind of information ;o)
Thank you,
Eric.
I know each plugin is individually supported but I’m struggling to figure out how to enable the additional stats on hosts?
I’ve installed the plugin but I’m not seeing the availability of the additional agent nor additional checks on any of the hosts after scanning.
Thanks
Andrew
I used the command
check_mk -P
install foo-1.0.mkp
is it not enough ?
Thank you,
Eric.
Thanks
Andrew
If the mkp contains an agent plugin you have to put it in the right folder at agent host. Just like I already wrote.
Eric Lecocq Eric.Lecocq@prodata-systems.be schrieb am Mo., 30. Mai 2016 11:07:
I used the command
check_mk -P
install foo-1.0.mkp
is it not enough ?
From: Marcel Schulte [mailto:schulte.marcel@gmail.com]
Sent: vendredi 27 mai 2016 18:50
To: Eric Lecocq Eric.Lecocq@prodata-systems.be; Andrew Speer aspeer@siue.edu; checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] NFS perfromance data plugin - nfsperf-1.0.1.mkp
Hi Andrew, Eric,
-20”).
Regards,
Marcel
Thank you,
Eric.
Thanks
Andrew
Ok,
I have done this. I will check if it’s ok.
Best regards,
Eric.
I used the command
check_mk -P
install foo-1.0.mkp
is it not enough ?
Hi Andrew, Eric,
-20”).
Regards,
Marcel
Thank you,
Eric.
Thanks
Andrew
