Hello everybody,
I am now testing check_mk a lot and I would like to ask you for an advise.
I had my check_mk up and running on my local virtual server. Now I want to test distributed monitoring and I moved my site to a new virtual computer in azure cloud.
That should be my new monitoring master. On the old server I created a new site and connected both sites via livestatus. The connection seems to work good but when I try synchronize the configuration
I receive following error message:
State: Failed. Started at: 10:52:50. Finished at: 10:52:52.
Failed: Got invalid data:
Internal automation error: Error running automation call restart (exit code 1), error:
not all arguments converted during string formatting
File “/omd/sites/cosmotel_h/lib/python/cmk/gui/wato/pages/automation.py”, line 186, in _execute_automation_command
html.write(repr(automation.execute(automation.get_request())))
File “/omd/sites/cosmotel_h/lib/python/cmk/gui/wato/pages/activate_changes.py”, line 519, in execute
return cmk.gui.watolib.activate_changes.execute_activate_changes(request.domains)
File “/omd/sites/cosmotel_h/lib/python/cmk/gui/watolib/activate_changes.py”, line 1172, in execute_activate_changes
warnings = domain_class().activate()
File “/omd/sites/cosmotel_h/lib/python/cmk/gui/watolib/config_domains.py”, line 69, in activate
return check_mk_local_automation(config.wato_activation_method)
File “/omd/sites/cosmotel_h/lib/python/cmk/gui/watolib/automations.py”, line 126, in check_mk_local_automation
err=errdata)
MKGeneralException: Error running automation call restart (exit code 1), error:
Where should I look now for a solution? Thank you.
Best regards,
Jiri
