Hi All,
I have a problem here in triggering Notifications. i.e i have 2 Notifications rules set for storage volumes.
I have set threshold values 85% Warning & 90% Critical assigned for storage hosts and are working fine.
Assigned new rule with an threshold values 90% Warning & 95% Critical assigned for the same storage volumes and this rule is not working.
receiving the alerts for rule 1 above 85-90 thresholds, rule 2 also notifies me about same 85-90% thresholds but not for 90-95% thresholds.
can anyone provide me an solution on this??
Regards,
Sandeep Kumar Ballari
Regards,
Hi Sandeep,
if you define different thresholds for the same service then only the threshold first “found” will be used.
Take a look at your threshold rules and see what rule comes first (from the top to the bottom).
If this rule is the 85% rule then all is correct.
Inside a notification rule you cannot bind anything to thresholds.
Thresholds are only important for the checking and to determine a state change.
Best regards
Andreas
PS: new location for all CheckMK questions and requests - https://forum.checkmk.com
Am So., 8. Dez. 2019 um 15:38 Uhr schrieb sandeep kumar sonuballarisandeep@gmail.com:
Hi All,
- I have set threshold values 85% Warning & 90% Critical assigned for storage hosts and are working fine.
- Assigned new rule with an threshold values 90% Warning & 95% Critical assigned for the same storage volumes and this rule is not working.
Regards,
Regards,
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
