Hello All,
I have a custom check that parses output like:
hw.sensors.mfi0.drive0=online (sd0), OK
hw.sensors.mfi0.drive1=online (sd1), OK
The check is working as expected, and the graphs are display correctly. However, I have not figured out how supply a “real” value for the MAX_HD variable (show in the snippet below).
As you can see, this host has only 2 drives, so an extra graph is drawn outside
of my defined graph (see below). I created a “drive_count”
perfdata point and I can use this variable in web/plugins/metrics/custom_check.py, but I have not figured out how to make “drive_count” the value for “MAX_HD”. Can anyone point me in the right direction?
MAX_HD =
3
for
i in
range(MAX_HD):
metric_info["drive%d"
% i] =
"title"
: “Drive %s” %(i),
"unit"
: “count”,
"color"
: “#eeabee”,
this generator creates data for a single graph using all found “drives”
drives_generator
= ( (drive, “line”) for drive
in re.findall(“drive\d+”,
“”.join(metric_info.keys())) )
graph_info[“drives” ]
"title"
: “Active Drives”,
"metrics"
: [m for m
in drives_generator],
