[Check_mk (english)] Performance issues on 1.2.8p5, what is this process doing?
Using 1.2.8p5, I’m running into some performance issues that I think is causing some of my webinject tests to fail (timeout). Periodically, I’ll see a bunch of these processes start (one for each client?) pegging all cores
of the CPU to 100% What is this doing?
python /omd/sites/SJC/share/check_mk/modules/check_mk.py --defaults /omd/sites/SJC/etc/check_mk/defaults
–inv-fail-status=1 --hw-changes=0 --sw-changes=0 --cache --inventory-as-check
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of NAVEX Global® Inc. and the intended recipients and may contain confidential and privileged information. Any unauthorized review, use, disclosure, or distribution
is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
Thomas Mashos| System Engineer, IT Hosted Operations
NAVEX Global: The Ethics and Compliance Experts
Hi Thomas,
This is the hardware / software inventory check and should only run every four hours. If you have a check interval of one minute for this check, you need to create a rule for a longer interval. This can be one of the performance issues. This happened only for upgrade installations on my systems. On new installed site the check interval was correct.
If you don’t need the hardware/software inventory you can also disable this feature for some or all host with a rule.
Best regards
Andreas
Thomas Mashos TMashos@navexglobal.com schrieb am Di., 12. Juli 2016 um 19:29:
checkmk-en mailing list
I did have that enabled for a bit, but I thought I removed it. Just checked and I do see it on one of the hosts so I’ve disabled the check since it appears that is for specific
hardware info and that I should still get basic info (disk space, etc). Hopefully that will resolve it, we’ll know in a few hours.
Sent: Tuesday, July 12, 2016 10:57:58 AM
To: Thomas Mashos; checkmk-en
Subject: Re: [Check_mk (english)] Performance issues on 1.2.8p5, what is this process doing?
Hi Thomas,
Best regards
Andreas
Using 1.2.8p5, I’m running into some performance issues that I think is causing some of my webinject tests to fail (timeout). Periodically, I’ll see a bunch of these processes start (one for each client?) pegging all cores of
python /omd/sites/SJC/share/check_mk/modules/check_mk.py --defaults /omd/sites/SJC/etc/check_mk/defaults --inv-fail-status=1
–hw-changes=0 --sw-changes=0 --cache --inventory-as-check
