Hi:
I have the 1.5.0p14 version of Check_MK. I have launched an inventory about two Cisco switches, and Port-channels and interfaces VLAN are not discovered. I have enabled in a rule the propVirtual(53) and ieee8023adLag(161), and I have done the inventory one more time, but the Port-channels and interfaces VLAN are not discovered neither. What could I do?
Thanks a lot.
Regards
Sure, I am sending it tomorrow. Right now I can’t access to the server.
Thank you very much!
Regards,
Agustín
El 24 abr 2019, a las 19:31, Marcel Schulte schulte.marcel@gmail.com escribió:
Hi Agustin,
- does your host match the rule?
- how is your rule configured, can you send us a screenshot of it (in listed view, not edit mode)?
BR,
Marcel
Agustín Márquez agustin.marquez@gmail.com schrieb am Mi., 24. Apr. 2019, 19:14: > > Hi:
Thanks a lot.
Regards
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
Hi
we monitor about 11.000 Cisco Switches and Accesspoints.
In our installation the "Network Interface and Switch Port Discover"is set to discover all possible options, i.e. all options are in the “Selected” table, also “Description as service name” is set to “Use description” and “Alias as servicename” is set to “Use alias”. Portchannels and VLANs are discovered successfully.
The “Downside” of this is: on stacked switches Check_MK easily finds 300+ services, so we have strict rules which services are available to restrict this to the most important ones (which are max. 4 dozen even on big stacked switches)
BR
Thomas
The DowNetwork Interface and Switch Port Discovery
Am Mi., 24. Apr. 2019 um 19:34 Uhr schrieb Agustín Márquez agustin.marquez@gmail.com:
Regards,
Agustín
Hi Agustin,
BR,
Marcel
Agustín Márquez agustin.marquez@gmail.com schrieb am Mi., 24. Apr. 2019, 19:14: > > > Hi:
Thanks a lot.
Regards
