Hello I’m new to check_MK here. I’m trying to find the rule to ignore this warning but could not find the Postfix Queue rule in Rule-Based Configuration of Host & Service Parameters
UNKN
Postfix Queue
UNKNOWN - Could not find summarizing line in output
Thanks,
Andy
Hi Andy,
it seems the check not works - UNKNOWN
To disable use a rule "Disabled checks" and select "postfix_mailq".
Horst
<checkmk-en@lists.mathias-kettner.de>
Gesendet von: "checkmk-en"
<checkmk-en-bounces@lists.mathias-kettner.de>
Hello I'm new to check_MK here. I'm trying to find the rule to ignore this
UNKN | |Postfix Queue | |
>UNKNOWN - Could not find summarizing line in output |
Thanks,
Andy_______________________________________________
checkmk-en mailing list
Von: Andy Ân Nguy?n <annguyen251@hotmail.com>
An: "checkmk-en@lists.mathias-kettner.de"
Datum: 11.08.2017 08:14
Betreff: [Check_mk (english)] Postfix queue check unknown - how to clear
What output does the agent give in the postfix section?
Regards,
Evy
On 11 August 2017 08:57:34 CEST, Horst.Linke@drv-bund.de wrote:
Hi Andy,
Horst
Thanks,
Andy
the output based on telnet port 6556:
postfix/postfix-script: error: unknown command: ‘’
postfix/postfix-script: fatal: usage: postfix start (or stop, reload, abort, flush, check, status, set-permissions, upgrade-configuration)
Thanks,
Andy
From: checkmk-en checkmk-en-bounces@lists.mathias-kettner.de on behalf of Evy Bongers lists+check-mk@evybongers.nl
Sent: Friday, August 11, 2017 9:47 AM
To: checkmk-en@lists.mathias-kettner.de; Horst.Linke@drv-bund.de
Subject: Re: [Check_mk (english)] Antwort: Postfix queue check unknown - how to clear
Regards,
Evy
Hi Andy,
Horst
Thanks,
Andy
checkmk-en
Info Page - Mathias Kettner
This
list is intended for discussion between users check_mk. To see the collection of prior postings to the list, visit the checkmk-en Archives.
checkmk-en
This
oops sorry I think this is the right output, please discard the last message.
(postfix,80988,3388,00:00:00,1751) pickup -l -t fifo -u
(root,80908,912,00:00:39,7477) /usr/libexec/postfix/master
(postfix,81160,1212,00:00:18,7486) qmgr -l -t fifo -u
<<<postfix_mailq>>>
Connection closed by foreign host.
Thanks,
Andy
From: checkmk-en checkmk-en-bounces@lists.mathias-kettner.de on behalf of Andy Ân Nguyễn annguyen251@hotmail.com
Sent: Friday, August 11, 2017 10:35 AM
To: checkmk-en@lists.mathias-kettner.de; Horst.Linke@drv-bund.de; lists@evybongers.nl
Thanks,
Andy
Regards,
Evy
Hi Andy,
Horst
Thanks,
Andy
checkmk-en
This
checkmk-en
This
