This message may contain confidential and privileged information. If it has been sent to you in error, please reply to advise the sender of the error and then immediately permanently delete it and all attachments to it from your systems. If you are not the intended recipient, do not read, copy, disclose or otherwise use this message or any attachments to it. The sender disclaims any liability for such unauthorized use. PLEASE NOTE that all incoming e-mails sent to PDF e-mail accounts will be archived and may be scanned by us and/or by external service providers to detect and prevent threats to our systems, investigate illegal or inappropriate behavior, and/or eliminate unsolicited promotional e-mails (“spam”). If you have any concerns about this process, please contact us atlegal.department@pdf.com
Hello Daniel,
I had the same issue today and sent a PR to Tribe29 to fix it
Kind Regards
Thorsten Bruhns
Am Di., 15. Okt. 2019 um 08:27 Uhr schrieb Daniel Fink (PDF) <daniel.fink@pdf.com>:
Hallo liste,
Ich habe eine PostgreSQL datenbank auf Centos-6 laufen und den monitoring Agent installiert.
Es zeigt die Datenbanken und alles andere erfolgreich an, nur die Instanz selbst wird als „not running“ registriert.
Wie detektiert der Agent ob es läuft oder nicht?
Grüße,
DANIEL FINK
Senior Software Engineer
tel (+49) 89.767062.20
fax(+49) 89.767062.11
email daniel.fink@pdf.com
PDF Solutions GmbH
(a PDF Solutions Company)
Managing Director: Kimon Michaels
Schwanthalerstr. 10
D-80336 München, Germany
München HRB 87307
DE 128214899
www.pdf.com
This message may contain confidential and privileged information. If it has been sent to you in error, please reply to advise the sender of the error and then immediately permanently delete it and all attachments to it from your systems. If you are not the intended recipient, do not read, copy, disclose or otherwise use this message or any attachments to it. The sender disclaims any liability for such unauthorized use. PLEASE NOTE that all incoming e-mails sent to PDF e-mail accounts will be archived and may be scanned by us and/or by external service providers to detect and prevent threats to our systems, investigate illegal or inappropriate behavior, and/or eliminate unsolicited promotional e-mails (“spam”). If you have any concerns about this process, please contact us at legal.department@pdf.com
This message may contain confidential and privileged information. If it has been sent to you in error, please reply to advise the sender of the error and then immediately permanently delete it and all attachments to it from your systems. If you are not the intended recipient, do not read, copy, disclose or otherwise use this message or any attachments to it. The sender disclaims any liability for such unauthorized use. PLEASE NOTE that all incoming e-mails sent to PDF e-mail accounts will be archived and may be scanned by us and/or by external service providers to detect and prevent threats to our systems, investigate illegal or inappropriate behavior, and/or eliminate unsolicited promotional e-mails (“spam”). If you have any concerns about this process, please contact us at legal.department@pdf.com._______________________________________________
checkmk-en mailing list
Manage your subscription or unsubscribe https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
