[Check_mk (english)] problem with Ubuntu 18.04.1 LTS and installing raw 1.5.0p6
Thanks for the replies.
So the ISO I used that was failing was "ubuntu-18.04.1-live-server-amd64.iso".
I just installed using this ISO and Check_MK is live!!! "ubuntu-18.04.1-server-amd64.iso"
The first ISO is the one you get from the main Ubuntu server download...
Have a good remainder of the week!
-----Original Message-----
Sent: Monday, October 22, 2018 4:48 PM
Subject: problem with Ubuntu 18.04.1 LTS and installing raw 1.5.0p6
I am having difficulty on an install where libpango1.0-0 is a dependency.
No matter what I do I cannot get past the following errors:
root@ubuntu:~# gdebi ~/check-mk-raw-1.5.0p6_0.bionic_amd64.deb
Reading package lists... Done
Building dependency tree
  ----snip----
Setting up rpm (4.14.1+dfsg1-2) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Selecting previously unselected package check-mk-raw-1.5.0p6.
(Reading database ... 131178 files and directories currently installed.)
check-mk-raw-1.5.0p6 depends on libpango1.0-0; however:
  Package libpango1.0-0 is not installed.
dpkg: error processing package check-mk-raw-1.5.0p6 (--install):
dependency problems - leaving unconfigured Processing triggers for ureadahead (0.100.0-20) ...
Processing triggers for systemd (237-3ubuntu10.3) ...
Processing triggers for man-db (2.8.3-2) ...
Errors were encountered while processing:
root@ ubuntu:~# apt search libpango1.0-0 Sorting... Done Full Text Search... Done libpango1.0-0/bionic 1.40.14-1 amd64
  Layout and rendering of internationalized text (transitional package)
root@ubuntu:~# apt install libpango1.0-0 Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
libpango1.0-0 : Depends: libpango-1.0-0 (= 1.40.14-1) but 1.40.14-1ubuntu0.1 is to be installed
                 Depends: libpangocairo-1.0-0 (= 1.40.14-1) but 1.40.14-1ubuntu0.1 is to be installed
                 Depends: libpangoft2-1.0-0 (= 1.40.14-1) but 1.40.14-1ubuntu0.1 is to be installed
                 Depends: libpangox-1.0-0 (>= 0.0.2-2~) but it is not going to be installed
                 Depends: libpangoxft-1.0-0 (= 1.40.14-1) but 1.40.14-1ubuntu0.1 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
root@ubuntu:~# apt --fix-broken install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  apache2 apache2-bin apache2-data apache2-utils debugedit fping freeradius-common freeradius-config freeradius-utils graphviz lcab libann0 libapr1 libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap libarchive13
  libcdt5 libcgraph6 libdbi-perl libdbi1 libdw1 libevent-1.4-2 libfile-copy-recursive-perl libfl2 libfreeradius3 libgd3 libgsf-1-114 libgsf-1-common libgts-0.7-5 libgts-bin libgvc6 libgvpr2 libice6 libjansson4
  liblab-gamut1 libldb1 libltdl7 liblua5.2-0 libnet-snmp-perl libnspr4 libnss3 libpathplan4 libpoppler73 libpython-stdlib libpython2.7 libpython2.7-minimal libpython2.7-stdlib librpm8 librpmbuild8 librpmio8
  librpmsign8 libsensors4 libsm6 libsmbclient libsnmp-base libsnmp-perl libsnmp30 libsodium23 libtalloc2 libtdb1 libtevent0 libtirpc1 libwbclient0 libwebp6 libxaw7 libxmu6 libxpm4 libxt6 php-cgi php-cli php-common
  php-gd php-json php-pear php-sqlite3 php-xml php7.2-cgi php7.2-cli php7.2-common php7.2-gd php7.2-json php7.2-opcache php7.2-readline php7.2-sqlite3 php7.2-xml poppler-data poppler-utils pyro python python-crypto
  python-ldb python-minimal python-samba python-talloc python-tdb python2.7 python2.7-minimal rpcbind rpm rpm-common rpm2cpio samba-common samba-common-bin samba-libs smbclient snmp ssl-cert unzip update-inetd
  xinetd
Use 'apt autoremove' to remove them.
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 361 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 156422 files and directories currently installed.) Removing check-mk-raw-1.5.0p6 (0.bionic) ...
root@ubuntu:~# apt install libpango1.0-0 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
E: Unable to correct problems, you have held broken packages.
root@wb-ubuntu:~#
