Hi @ all,
i defined a cluster of esx nodes. Single nodes are working fine. The cluster troughs me this error
Output of check plugin
UNKNOWN - Exception in precompiled check: ‘NoneType’ object is not iterable (details in long output)
Long output of check plugin (multiline) Traceback:
File “/omd/sites/prod/var/check_mk/precompiled/MDCESX-87”, line 2074, in
File “/omd/sites/prod/var/check_mk/precompiled/MDCESX-87”, line 694, in do_check
File “/omd/sites/prod/var/check_mk/precompiled/MDCESX-87”, line 949, in do_all_checks_on_host
File “/omd/sites/prod/var/check_mk/precompiled/MDCESX-87”, line 214, in get_host_info
TypeError: ‘NoneType’ object is not iterable
But this problem is only on the webinterface.
cmk –nv MDCESX-87 works fine
any idea?
Mathias Decker
IT User-Support / Monitoring / Windows- and Linux-Server
Max-Delbrueck-Centrum
Robert-Roessle-Str. 10
D-13125 Berlin
house 23 / room 210
phone:+49-(0)30-9406 2574
hotline: +49-(0)30-9406 4440
mail: mathias.decker@mdc-berlin.de
Hi Mathias,
'cmk' does not call the precompiled checks.
Did you try reinventorizing all nodes and cluster host and running
'cmk -C' after that?
Just my 2 cent...
HTH,
Marcel
2013/6/25 mathias.decker@mdc-berlin.de <mathias.decker@mdc-berlin.de>:
Hi @ all,
UNKNOWN - Exception in precompiled check: 'NoneType' object is not iterable
File "/omd/sites/prod/var/check_mk/precompiled/MDCESX-87", line 2074, in
File "/omd/sites/prod/var/check_mk/precompiled/MDCESX-87", line 694, in
do_check
File "/omd/sites/prod/var/check_mk/precompiled/MDCESX-87", line 949, in
File "/omd/sites/prod/var/check_mk/precompiled/MDCESX-87", line 214, in
get_host_info
TypeError: 'NoneType' object is not iterable
any idea?
Mathias Decker
D-13125 Berlin
house 23 / room 210
checkmk-en mailing list
Already did that - hadnt helped
-----Original Message-----
From: Marcel Schulte [mailto:schulte.marcel@gmail.com]
Sent: Dienstag, 25. Juni 2013 09:43
To: Decker, Mathias
Subject: Re: [Check_mk (english)] problems with esx clusters
Hi Mathias,
Did you try reinventorizing all nodes and cluster host and running 'cmk -C'
after that?
Just my 2 cent...
HTH,
Marcel
Hi @ all,
in
in do_check
in get_host_info
cmk -nv MDCESX-87 works fine
any idea?
Mathias Decker
D-13125 Berlin
house 23 / room 210
You could execute the precompiled file by 'python
/omd/sites/prod/var/check_mk/precompiled/MDCESX-87' - should give same
error as described.
...don't know (no failed checks here) but maybe 'python -dvvv
/omd/sites/prod/var/check_mk/precompiled/MDCESX-87' gives some more
useful information on that error.
To: Decker, Mathias
Hi Mathias,
after that?
Just my 2 cent...
HTH,
Marcel
Hi @ all,
in
in do_check
in get_host_info
any idea?
Mathias Decker
D-13125 Berlin
house 23 / room 210
Yep - that gives me the same error
Every other cluster works fine.
Sent: Dienstag, 25. Juni 2013 14:53
To: Decker, Mathias
/omd/sites/prod/var/check_mk/precompiled/MDCESX-87' - should give same error
as described.
/omd/sites/prod/var/check_mk/precompiled/MDCESX-87' gives some more useful
To: Decker, Mathias
Hi Mathias,
-C'
after that?
Just my 2 cent...
HTH,
Marcel
Hi @ all,
in
in do_check
in get_host_info
any idea?
Mathias Decker
D-13125 Berlin
house 23 / room 210
Try removing the precompiled files of cluster and its nodes,
reinventorizing all these and executing 'cmk -C' (all that in
terminal, not Multisite) - any errors during this procedure? And
executing the precompiled cluster file after that? Same error?
To: Decker, Mathias
as described.
To: Decker, Mathias
Hi Mathias,
-C'
after that?
Just my 2 cent...
HTH,
Marcel
Hi @ all,
in
in do_check
in get_host_info
any idea?
Mathias Decker
D-13125 Berlin
house 23 / room 210
Doesnt help to
Btw: i'm on the latest git version
Sent: Dienstag, 25. Juni 2013 15:06
To: Decker, Mathias
Try removing the precompiled files of cluster and its nodes, reinventorizing
all these and executing 'cmk -C' (all that in terminal, not Multisite) - any
errors during this procedure? And executing the precompiled cluster file
To: Decker, Mathias
error as described.
To: Decker, Mathias
Hi Mathias,
'cmk
-C'
after that?
Just my 2 cent...
HTH,
Marcel
Hi @ all,
2074, in
in do_check
in get_host_info
any idea?
Mathias Decker
D-13125 Berlin
house 23 / room 210
Sorry, no GIT used here so no help available.
Best regards,
Marcel
Doesnt help to
To: Decker, Mathias
To: Decker, Mathias
error as described.
To: Decker, Mathias
Hi Mathias,
'cmk
-C'
after that?
Just my 2 cent...
HTH,
Marcel
Hi @ all,
2074, in
in do_check
in get_host_info
any idea?
Mathias Decker
D-13125 Berlin
house 23 / room 210
The solution:
The cluster needs to have the same agent type defined as the nodes. That's
all.
Best
mathias
To: Decker, Mathias
Hi Mathias,
after that?
Just my 2 cent...
HTH,
Marcel
Hi @ all,
in
in do_check
in get_host_info
any idea?
Mathias Decker
D-13125 Berlin
house 23 / room 210
