Hi everyone, my check_mk on virtual machine (hypervisor ProxMox ve 5.1) has all services and hosts in stale state. It happens since I start to add new hosts. I have above 1800 hosts. I gave to system 32 of 54 cores, processors - 56 x Intel® Xeon® CPU E5-2680 v4 @ 2.40GHz (2 Sockets) x2
By taking a look in htop, ive not seen anything suspicious.
my problem looks like on screenshot 2
Could anyone help me with this? Or give me a right direction to find a solution?
is this a new installation? If not, did something change on the config side?
Which version of 1.4.0 is it? Core (i guess it is) or Enterprise?
In general stale and/or hosts mean that the core is not able to compute the host/service check-queries in a sufficient time (i.e. “overcharged”).
What is host/service check interval?
Which checks do you have, i.e. SNMP, agent, SSH…
Also imprtant to know:
I do not know Proxmox, but in general in a VM all CPU cycles are virtualized, so for example in vSphere you can preserve a certain amout of CPU power directly for a VM to compensate this.
BR
Am Di., 29. Jan. 2019 um 14:11 Uhr schrieb Александр Чекалов chekalov@samrct.ru:
Hi everyone, my check_mk on virtual machine (hypervisor ProxMox ve 5.1) has all services and hosts in stale state. It happens since I start to add new hosts. I have above 1800 hosts. I gave to system 32 of 54 cores, processors - 56 x Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz (2 Sockets) x2
BR
please read carefully. I suggested to disable SNMP just to test if staleness disappears, which could be an indicator that the Nagios core is overloaded.
You still miss the information about your config, Linux etc
This is like looking into a glass bowl
BR
Am Mi., 30. Jan. 2019 um 06:35 Uhr schrieb Александр Чекалов chekalov@samrct.ru:
Thanks for your advices, Thomas. But snmp is very useful for my work. I need to know if interfaces down or up and most important I need to check the MAC addresses of hosts, to actualize ip plan and schema. So disable snmp is not an option for me. How do you think, why disabling notifications is worked for me?
BR
