I am trying to add a vCenter host to my test instance and i continue to get an error. The error i get is the following: Proxy Error
The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request POST /abco/check_mk/wato.py.
Reason: Error reading from remote server
Here is my test setup:
Server 1: Main instance: Consolidated dashboard, WATO configuration, etc (this is the abco mentioned in the error)
localmaster
Server 2: Test instances: Each instance represents an environment that will be deployed ( 2 local, 2 remote).
localdev
localprod
remotedev
remoteprod
I have two vCenter servers i want to monitor from remoteprod. I already have 1 set up and it is working fine. When i try to add the 2nd vCenter server, it never completes the service discovery. I have done the following troubleshooting steps:
verified i can ping the box from remoteprod
verified that i can hit the 6556 port from remote prod; when i do it returns all the data i expect to my terminal session
verified i can log in using the supplied credentials; its using the same UN/PW combo my other vCenter server is.
Is this a timeout issue? Could it be that this server is returning much more data than the other? Are there logs someplace that might give me some idea what is really going on.
Thanks,
Mark
*“…Run in such a way as to get the prize.” *(1 Cor 9:24, NIV)
This is not uncommon. You can always run the inventory from the command line. You can also just reload etc from command line also whenever you face the timeout issue in WATO.
localmaster
localdev
localprod
remotedev
remoteprod
Thanks,
Mark
Proxy Error
localmaster
localdev
localprod
remotedev
remoteprod
steps:
Thanks,
Mark
