Andreas…would you be able to give a “rough” estimate for the API work involved (to create a new special agent based around the Purestorage API….like we did before for the Hivemanager API)…that way we can see if we can
get our end-client to finance this from their side?
For the Hivemanager agent, it was around 16 credits…maybe 20 in the end with updates…can we estimate something similar for Purestorage?
Kind regards,
Simon
From: “Nadeem Hanif (T2 International)” nadeem.hanif@take2games.com
Date: Tuesday, 4 September 2018 at 13:23
To: Simon Hogg simon.hogg@edificom.ch, Andreas Döhler andreas.doehler@gmail.com
Cc: “checkmk-en@lists.mathias-kettner.de” checkmk-en@lists.mathias-kettner.de
Subject: RE: [Check_mk (english)] Purestoreage
Simon I am happy to do this once we know the amount of hours etc needed for the work to complete
Andreas I am getting an error still with this
API Error:Your request timed out after 110 seconds. This issue may be related to a local configuration
problem or a request which works with a too large number of objects. But if you think this issue is a bug, please send a crash report.
Sent: 04 September 2018 10:24
To: Andreas Döhler andreas.doehler@gmail.com; Nadeem Hanif (T2 International) nadeem.hanif@take2games.com
Subject: Re: [Check_mk (english)] Purestoreage
Hello all,
We are interested in the Purestorage monitoring as well, and the API approach would be preferred.
Andreas, would you be able to give a rough estimate of the work hours required for this?
Nadeem, would you (or anyone else) be interested in splitting the costs of the devopment in order to get this plugin developed?
Kind regards,
Simon
Simon Hogg COO
EDIFICOM SA Rue de la Vernie 12 | CH-1023 Crissier
T +41 21 313 23 13 |
M +41 79 489 12 98
simon.hogg@edificom.ch |
www.edificom.ch
From: checkmk-en <checkmk-en-bounces@lists.mathias-kettner.de > on behalf
of Andreas Döhler andreas.doehler@gmail.com
Date: Monday, 3 September 2018 at 09:12
To: “Nadeem Hanif (T2 International)” nadeem.hanif@take2games.com
Hi Nadeem,
if you want to use the classic Nagios check, then you should place the check inside “~/local/lib/nagios/plugins” inside your monitoring site.
After this is done you can define a rule for “Active Checks” → “Classical active and passive Monitoring checks”. To access the plugin use the $USER2$ macro for the correct path to the plugin.
A better solution would be to build a special agent using the purestorage API. But this is a bigger task.
Best regards
Andreas
Nadeem Hanif (T2 International) nadeem.hanif@take2games.com schrieb am Mo., 3. Sep. 2018 um 08:09 Uhr:
Hey all
Anyone able to get a working check implemented for a purestoreage device
Found this but not sure it’s the best way or really where to place the script
https://github.com/purestorage/nagios/blob/master/README.pod
Nadeem Hanif
Snr Systems Engineer
Take Two Games inc.
Sent from my iPhone
checkmk-en mailing list
