Is it possible to set reoccurring maintenance for any component in check_mk? I would really appreciate your response.
Thanks
Ashish
Thanks
Ashish
Ashish,
I have used the a cron script in the past.
Serverfault had a great piece of just excluding the period from the time period the host is in use which is more elegant.
http://serverfault.com/questions/297132/nagios-how-do-i-schedule-a-regular-period-of-downtime
HTH,
Bill
On Fri, Aug 22, 2014 at 5:13 PM, Jain, Ashish (NBCUniversal) Ashish.Jain@nbcuni.com wrote:
Hello,Is it possible to set reoccurring maintenance for any component in check_mk? I would really appreciate your response.ThanksAshish
checkmk-en mailing list
Thank you Bill.
I have a super large environment and we get lots of request on this so the time period setup might require more work than setting up some automation with hourly
cron. Thank you for the great advise.
http://exchange.nagios.org/directory/Addons/Scheduled-Downtime/Schedule-Downtime-via-cron/details
-Ashish
Ashish,
HTH,
Bill
Thanks
Ashish
</details>
