if we would use the CEE-Version, there is an build in ReporingEngine.
Can we use this also for generate reporings from other Sources, eg an SQL Database?
Thx, regards
Juergen
Thx, regards
Juergen
No. It's not a generic reporting engine like Jasper Reports but a
specific for the monitoring system CEE. It gets the data via livestatus
from the Check_MK micro core.
Regards
SQL Database?
Robert Sander
Heinlein Support GmbH
Tel: 030 / 405051-43
Fax: 030 / 405051-19
Zwangsangaben lt. §35a GmbHG:
HRB 93818 B / Amtsgericht Berlin-Charlottenburg,
Geschäftsführer: Peer Heinlein -- Sitz: Berlin
