[Check_mk (english)] Running a script at specific time
I need to have a script that does some checks run at at hh:50. How can this be done?
Cron?
Live long and prosper
Robin `ypid` Schneider
this be done?
On *nix, use cron.
On Windows, use the task scheduler. (haven’t tried hourly tasks, but
I would hope it works)
Have you script write it's output to a file, then have a check_mk
check (local, plugin, etc)
read and process the output file when the agent runs. (basically
cache the results till the
next HH:50 run)
On 07/07/2016 02:52 PM, Rick Kohrs
checkmk-en mailing list
checkmk-en@lists.mathias-kettner.dehttp://lists.mathias-kettner.de/mailman/listinfo/checkmk-en
Forgot to mention that Passive Checks might come in handy, in combination with
Cron.
On 07.07.2016 21:11, Rick Kohrs wrote:
Originally I had a script that was triggered by cron and wrote out a file.
The file was then picked up by a script running via check_mk. Our
preference is to avoid using cron.
The check_mk agent can pick up files in a spool directory (usually
/var/lib/check_mk_agent/spool) and append their contents to its output.
No need to implement a plugin or local check if your job or application
is able to produce an agent section.
Regards
On 07.07.2016 21:19, Jam Mulch wrote:
On *nix, use cron.
On Windows, use the task scheduler. (haven't tried hourly tasks, but I
Have you script write it's output to a file, then have a check_mk check
read and process the output file when the agent runs. (basically cache
next HH:50 run)
Robert Sander
Heinlein Support GmbH
Linux: Akademie - Support - Hosting
Tel: 030-405051-43
Fax: 030-405051-19
Zwangsangaben lt. §35a GmbHG:
HRB 93818 B / Amtsgericht Berlin-Charlottenburg,
Geschäftsführer: Peer Heinlein -- Sitz: Berlin
