[Check_mk (english)] Running check_mk behind proxy - changing url_prefix
Hi all,
I’m trying to move a deployment to docker, and I can’t work out how to run it behind a proxy. I’ve found some documentation for multi-site installs around url_prefix, but nothing for a standard installation.
My use case is that I want to proxy requests from https://mysite.com/monitoring/ to my check_mk_server.mysite.com:5000
Any documentation / pointers would be much appreciated,
Thanks,
Wayne
Hi Wayne,
The way I interpret your issue makes me think you need another system (non-Check_MK) to use as a proxy.
I don’t think this is strictly a Check_MK thing.
Two alternatives come to mind, but both require the second URL
to be reachable for end users.
As this is not proxying it’s probably not of any use, but here goes.
Distributed setup:
Have a main site at https://mysite.com/monitoring and add the docker site(s) as slave site(s).
Main site shouldn’t monitor anything, use it as Check_MK frontend only and let this main site do the notifying.
Mod_rewrite:
https://httpd.apache.org/docs/current/mod/mod_rewrite.html. Rewrite the URL on the fly.
Again, this is not proxying – second site must be reachable for end users.
Arno
On Behalf Of Wayne Pascoe
Hi all,
to my
Thanks,
Wayne
Hi Wayne,
Distributed setup:
Mod_rewrite:
Arno
Hi all,
to my
Thanks,
Wayne
I set up a similar scenario using proxypass in apache:
ProxyRequests Off
ProxyPreserveHost On
# I chose to use the url http://apache-server.site/monitor/ instead of the root, but you could do it there too...
ProxyPassMatch "^/monitor/(.*)$" "https://my_check_mk_server.site/monitor/$1" connectiontimeout=5 timeout=450
ProxyPassReverse "/monitor/" "https://my_check_mk_server"
Chris
On Mon, 22 Oct 2018 09:37:51 +0100 Wayne Pascoe <wayne@penguinpowered.org> wrote:
Hi Arno,
The issue I’m trying to solve is that check_mk.mysite.com:5000 cannot be
accessible by end users.
The plan is to use nginx or apache on a publicly available server to proxy
requests to check_mk
With other applications that we do this with (e.g kibana) we specify a url
prefix or base url of Mysite.com/monitoring in the kibana config. Kibana then
uses this to rewrite all of the links it sends back so that they are valid.
For example, it may normally return a link of mysite.com/settings/indexpage
but with this configuration it would return a link of
mysite.com/monitoring/indexpage
Regards,
> On 22 Oct 2018, at 09:09, Arno Wijnhoven <arnow@vsnsystemen.nl> wrote:
> Hi Wayne,
> (non-Check_MK) to use as a proxy. I don’t think this is strictly a Check_MK
> thing.
> check_mk_server.mysite.com:5000 to be reachable for end users. As this is
> Distributed setup:
> site(s) as slave site(s). Main site shouldn’t monitor anything, use it as
> Mod_rewrite:
> mod_rewrite - Apache HTTP Server Version 2.4. Rewrite the URL
> on the fly. Again, this is not proxying – second site must be reachable for
> end users.
> Arno
> From: checkmk-en [mailto:checkmk-en-bounces@lists.mathias-kettner.de] On
> Behalf Of Wayne Pascoe Sent: zondag 21 oktober 2018 21:04
> To: checkmk-en@lists.mathias-kettner.de
> Subject: [Check_mk (english)] Running check_mk behind proxy - changing
> url_prefix
> Hi all,
> I'm trying to move a deployment to docker, and I can't work out how to run
> it behind a proxy. I've found some documentation for multi-site installs
> around url_prefix, but nothing for a standard installation. My use case is
> check_mk_server.mysite.com:5000 Any documentation / pointers would be much
> appreciated,
> Thanks,
> Wayne
Hi Chris,
I’m still struggling with this a little. Does the proxypassreverse rewrite the URLs coming from check_mk ?
Where I’m at so far is:
Check_mk is running on http://somehost:6000/sitename/check_mk/ and I need to access it from https://example.com/arbitraryprefix/check_mk/
I can access check_mk for the first time at https://example.com/arbitraryprefix/check_mk/index.py - This works
However, all links in the returned page are invalid because they’re not aware of the proxy. So they’re things like https://example.com/sitename/check_mk/dashboard.py instead of https://example.com/arbitraryprefix/check_mk/dashboard.py
Did you have to do anything in addition to your proxy setup to make check_mk work at these URLs ?
Thanks,
Wayne Pascoe (gpg --keyserver www.co.uk.pgp.net --recv-keys 79A7C870)
ProxyRequests Off
I chose to use the url http://apache-server.site/monitor/ instead of the root, but you could do it there too…
ProxyPassMatch “^/monitor/(.*)$” “https://my_check_mk_server.site/monitor/$1” connectiontimeout=5 timeout=450
ProxyPassReverse “/monitor/” “https://my_check_mk_server”
Chris
On Mon, 22 Oct 2018 09:37:51 +0100 > Wayne Pascoe wayne@penguinpowered.org wrote:
Hi Arno,
Regards,
On 22 Oct 2018, at 09:09, Arno Wijnhoven arnow@vsnsystemen.nl wrote:
Hi Wayne,
thing.
Distributed setup:
Mod_rewrite:
end users.
Arno
url_prefix
Hi all,
appreciated,
Thanks,
Wayne
checkmk-en mailing list
