[Check_mk (english)] Settings for SVI’s
Hey, all!
Anyone have any insight on SVI settings? The priority they get for ping requests and the like is usually as low as it gets. Traffic prioritization for ICMP requests are low. As a result, you see latency or ping drops from switches or SVI’s altogether. However, servers plugged in to those switches are great, still sitting at acceptable ranges for response times. It’s quite normal, but does anyone account for this in some strategic fashion that works for them? As in, do you use a specific set of rules for switch rules and latency. I understand the WAN rules by default and the like, which could also be applied to those interfaces/devices as well, but was wondering if anyone has a good method they use for this scenario. Like, always assume host to be up? Monitor a service? Just curious what strategies you all may be using as opposed to relying on PING, since it’s really not a reliable resource, especially when the switches are performing intense backups for the hosts on it.
Thanks,
Brian
Hi Brian,
if you are speaking about Switch Virtual Interface then i cannot verify your problem.
Also if i read some Cisco documents right the ICMP loss will only happen if you try to sent to many packets to the device.
https://supportforums.cisco.com/t5/data-center-documents/packet-loss-when-pinging-from-to-a-nexus-7000/ta-p/3110226
I think it would be good if you try only to sent 2 or 3 ICMP packets per ping request. This should be no problem for the policing inside the switch.
At all of our monitored Cisco Nexus i cannot remember a problem like described.
br
Andreas
Brian Binder brian.binder@gmail.com schrieb am So., 10. Sep. 2017 um 15:51 Uhr:
Hey, all!
Thanks,
Brian
checkmk-en mailing list
Thanks, Andreas - I’ll try that technique, but it’s not just cisco - Juniper and hp also have similar behaviors.
Cisco goes over this here: https://supportforums.cisco.com/t5/wan-routing-and-switching/ping-icmp-and-priority/td-p/611529
I know that’s a forum post, though their tech support has also verified it; it’s just that if you monitor performance based on ICMP does its availability like you’d do with an SLA, it makes it seem like the switch has plenty of problems, but in reality it does not. Devices connected are great, but management interfaces of SVI’s aren’t treated quite the same.
I even have an hp switch (not high performance) where all the devices connected are like ~2 ms or less, but the SVI itself will usually come in at ~200-400 ms on a regular basis. This behavior will be regardless of a L2 or L3 boundary / hop between devices. Some of it is equipment-related, yes (regarding the SVI’s) but the results are the same on the servers plugged in to the switches. All those respond favorably, but the parent switches will show hiccups / timeouts, etc.
I deal with many different hardware types for switches; some SVI’s just behave slowly, but the devices connected are always within the low latencies I would expect. There have been many network discussions on forums regarding this, as your performance should be graded not by pinging SVI’s, but rather the devices connected to them. That’s why I wanted to inquire about how others handle this or if they even find it to be problematic. In many cases for me, I find it problematic for SVI’s, but not the connected devices.
I’ll continue to play around.
Thanks again,
Brian
Reply: Andreas Döhler andreas.doehler@gmail.com
Date: September 10, 2017 at 10:35:28 AM
To: Brian Binder brian.binder@gmail.com, checkmk-en@lists.mathias-kettner.de checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] Settings for SVI’s
Hi Brian,
br
Andreas
Hey, all!
it.
Thanks,
Brian
One thing you can try is the following setting.
Ping checks over the switch/router to the next end device should not be affected by this problem as it only occurs if you target the IP of the switch/router itself.
Second idea i have is to use not a normal ping check but a check if port 22 for SSH is reachable on the device.
For the host check command inside check_mk you can easily define other commands.
br
Andreas
Brian Binder brian.binder@gmail.com schrieb am So., 10. Sep. 2017 um 17:58 Uhr: > Thanks, Andreas - I’ll try that technique, but it’s not just cisco - Juniper and hp also have similar behaviors. > Cisco goes over this here: https://supportforums.cisco.com/t5/wan-routing-and-switching/ping-icmp-and-priority/td-p/611529
Thanks again,
Brian
Hi Brian,
br
Andreas
Hey, all!
it.
Thanks,
Brian
Thanks for the suggestions. I’m going to give these a shot and see how they perform :slight_smile:
On September 10, 2017 at 12:47:08 PM, Andreas Döhler (andreas.doehler@gmail.com) wrote:
br
Andreas
  • Juniper and hp also have similar behaviors.
devices.
Thanks again,
Brian
AM
Settings for SVI’s
Hi Brian,
device.
br
Andreas
Brian Binder brian.binder@gmail.com schrieb am So., 10. Sep. > > > 2017 um 15:51 Uhr:
Hey, all!
it.
Thanks,
Brian
