"Fix" worked.
So from availability report's perspective the system was in NA state since no events had been generated. Despite copying over the Nagios history the "UP" state did not apparently carry over from Nagios.
Or was the mistake that we shut down Nagios before copying over the archive? Should we have copied it while Nagios was still running?
- Dr. Antti Mäkelä | Senior Architect | CCIE #20962 -
- Vintor Oy, Itsehallintokuja 6, 02600 Espoo | www.vintor.fi -
-----Original Message-----
Sent: 20. heinäkuuta 2017 15:30
To: Marcel Schulte
Subject: RE: [Check_mk (english)] Smart ping, availability reports and host graphs
cmk -R didn't help.
Anyway, I (probably) found out what's the problem. We had no events since several of the hosts were consistently up during the migration and afterwards.
There was a host that had been rebooted recently, so it was unavailable for a while.
Since there never was an "UP" event for a host, it had no events whatsoever.
We can probably fix the issue by disconnecting the monitoring host from network for e.g. ten minutes to generate lots of "DOWN" events for all hosts, and then connect it back (generating "UP" events). Will test this theory.
Obviously, this should be handled a bit better...
From: Marcel Schulte [mailto:schulte.marcel@gmail.com]
Sent: 20. heinäkuuta 2017 15:25
To: Mäkelä, Antti
Subject: Re: [Check_mk (english)] Smart ping, availability reports and host graphs
Hi Antti,
please try executing "cmk -R" as siteuser and check if the availability is working after that.
If it's still not working I think that's a support case...
BTW: do you get host and service events displayed using the "events"
button at top of a view?
Regards,
Marcel
2017-07-20 12:54 GMT+02:00 Mäkelä, Antti <Antti.Makela@vintor.fi>:
Hi, perhaps I was not clear. The problem is that the historical data copied over from Nagios is correct and shows up fine even with CMC, but no new data is visible.
The availability for the period where CMC is running is showing up as NA.
We don't need ping times, but we do need the availability information.
________________________________________
Sent: Thursday, July 20, 2017 13:46
To: Mäkelä, Antti
host graphs
Hi Antti,
1) The CMC writes its history files in another place than Nagios (but
is able to read the later). You can copy all history files from Nagios
location to the CMC location and restart the core:
cp ~/var/nagios/archive/* ~/var/check_mk/core/archive/ cmk -R
2) With smartping no performance data is written. That's why the host
graphs are empty from the time of migration. But the (old) data is not
removed and so the CMC finds the xml and rrd files which leds to
showing the graphs/graph-icons in the GUI.
HTH,
Marcel
2017-07-18 13:27 GMT+02:00 Mäkelä, Antti <Antti.Makela@vintor.fi>:
for testing, we just migrated one of our monitoring sites from Nagios to CMC. Two things...
1) Availability reports. The hosts show N/A for availability ever since we switched to CMC. Is this normal? How can we get accurate availability reports for hosts or is it something that will start working later when enough data is gathered (I tried omd restart to check if status would be "flushed" by that).
2) I know that to monitor ping times, you need to set up an explicit "PING" check. However, if I don't do that, what's the "host graph" for? So far it's been empty. The migration guide at https://mathias-kettner.com/cms_cmc_migration.html only mentions that "after a conversion from a Nagios core the host checks at first provide no performance data". What does this "at first" even mean?
checkmk-en mailing list
