Hello list,
i upgraded check_mk to version „raw 1.2.8p8” and I don´t get snmp infos at the host overview anymore.
When i´m at the host-config and select “save and test” everything is fine. I get the info that snmp is available. But when I select the added host I only get ping information.
Is there another way to configure the hosts to get snmp information shown at the host overview (like printer toner status) and not only ping?
Best wishes,
Sarah
Did you clicked "Save manual check configuration" after discovery of
services?
regards
Stefan
Am 17.10.2016 um 10:58 schrieb Ringleb, Sarah:
Hello list,
i upgraded check_mk to version �raw 1.2.8p8� and I don�t get snmp infos
When i�m at the host-config and select �save and test� everything is
Best wishes,
Sarah
Sarah Ringleb
Fachinformatikerin FR Systemintegration
Phone: +49 531 8852 1270
Fax: +49 531 8852 1570
Mobil: +49 174 288 1169
mailto: Sarah.Ringleb@lineas.de <mailto:Sarah.Ringleb@lineas.de>
LINEAS Informationstechnik GmbH
Theodor-Heuss-Stra�e 2
38122 Braunschweig, Germany
Phone: +49 531 8852 0
Fax: +49 531 8852 1500
mailto: vertrieb@lineas.de <mailto:%20vertrieb@lineas.de>
http://www.lineas.de/>
Amtsgericht Braunschweig, HRB Nr. 204553
Gesch�ftsf�hrer: Frank Hildebrandt, Dr. Peter Mertinatsch, Dr. Michael
Goldapp
checkmk-en mailing list
Hm, looks like the agent type is set to Check_MK instead of SNMP. Can
you double check this in the hosts properties?
Am 17.10.2016 um 11:23 schrieb Ringleb, Sarah:
I dont have this option.
When I select "save and go to services" I get the message " Service discovery failed for this host: Cannot get data from TCP port 10.32.68.230:6556: [Errno 111] Connection refuse".
There are no services shown.
-----Urspr�ngliche Nachricht-----
Von: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de] Im Auftrag von Stefan Heitm�ller
Gesendet: Montag, 17. Oktober 2016 11:16
An: checkmk-en@lists.mathias-kettner.de
Betreff: Re: [Check_mk (english)] SNMP checks
Did you clicked "Save manual check configuration" after discovery of services?
regards
Stefan
Hello list,
i upgraded check_mk to version "raw 1.2.8p8" and I don�t get snmp
When i�m at the host-config and select "save and test" everything is
Best wishes,
Sarah
Sarah Ringleb
Goldapp
https://mathias-kettner.de/cms_wato_hosts.html#Basic%20Settings:%20Alias%20und%20IP-Adresse
Am 17.10.2016 um 11:33 schrieb Ringleb, Sarah:
I don�t find this option in the host properties anymore. This is what im missing.
I just have followings options when I open the host properties (hosts -> Edit properties of this host) :
- hostname
- permissions
- aliases
- ipv4 address
- parents
- Monitored on site
- Ip address family
There is no option to change the agent type to snmp. Or am I at the wrong place of the wato config?
Gesendet: Montag, 17. Oktober 2016 11:27
Hm, looks like the agent type is set to Check_MK instead of SNMP. Can you double check this in the hosts properties?
Stefan Heitm�ller
regards
Stefan
Hello list,
Best wishes,
Sarah
Sarah Ringleb
Michael Goldapp
I'm also running the Raw version at some sites and there it works. At
least, when adding a new host. Can you try to add a new host and check,
if the setting is there?
Am 17.10.2016 um 11:44 schrieb Ringleb, Sarah:
Jup, das ist das was ich vorher auch so kannte. Bei der Raw Version steht mir aber nur noch unter Host Tags "IP Address Family" zur Verf�gung. Mehr wird nicht mehr aufgelistet.
Gesendet: Montag, 17. Oktober 2016 11:39
- hostname
- permissions
- aliases
- ipv4 address
- parents
- Monitored on site
- Ip address family
Stefan Heitm�ller
Stefan Heitm�ller
regards
Stefan
Hello list,
Best wishes,
Sarah
Sarah Ringleb
Michael Goldapp
