[Check_mk (english)] SNMP firewall ports clarification
Hi there.
When i set a host to be monitored by snmp, (different vlans), and test it… i see on firewall lots of ports being used on destination. Is this correct?
Apart from 161/udp, i see from 33437/udp … up to 33523/udp.
It doesn’t seem to stop (33524, etc).
I thought only 161/udp would be used.
Is this correct? i need confirmation, before enabling all this ports.
Thanks for your time!
I don’t know in which direction do you see these ports used, not from OMD host to the destination.
If you use SNMP then only 161 is used.
Best regards
Andreas
Gerardo Ferreyra raptorg83@gmail.com schrieb am Mi., 5. Aug. 2015 19:01:
Hi there.
checkmk-en mailing list
We’ll meet in Munich for the 2nd Check_MK Conference!
Book your place now and be part of it.
October 18th-20th, 2015
http://mathias-kettner.com/conference
