Thank you, Andreas and Matthew, for your response.
So far, I have done the below:
- Created a test site on the same server and added the device (Agent type= SNMP (Networking device, Appliance) ). This device is queried using a public community string so I have not created any rules.
I am able to see the below checks now apart from the Interface eth, SNMP info, Uptime checks, etc:
- A Lot of FiberChannel Port x.xx checks
-Fabric Element checks
-PSU
-Temperature Sensors
- On the prod site, the same device (Agent type= SNMP (Networking device, Appliance)) only shows 4 checks:
-SNMP info
-Uptime
-Checkmk
-Interface eth
It looks like some kind of restriction/rule exists that is preventing the discovery of the other checks or something else.
On the Prod site >> Network and Switch Port discovery rule, I see a couple of rules there defined for some particular devices like different CISCO models and at the bottom, there is a generic rule defined like this:
Condition: Host has tag monitor via SNMP
Use description as service name for network interface checks: On
Network interface port types to discover: ethernetCsmacd(6), frameRelay(32), propVirtual(53), fibreChannel(56), fastEther(62), gigabitEthernet(117), ieee8023adLag(161)
- I tried to dump configuration about the hosts on test and prod site:
cmk -D
Test site:
Tags: site:test, snmp-only, prod, snmp, lan, wato, /wato/
Type of agent: SNMP (community: ‘public’, bulk walk: yes, port: default, inline: yes)
Prod site:
Tags: wan, site:prod, snmp, sl3, snmp-only, prod, wato, /wato/
Any pointers what else can be checked/looked into?
On Mon, Sep 23, 2019 at 9:44 PM Matthew.Stier@us.fujitsu.com Matthew.Stier@us.fujitsu.com wrote:
An issue I’ve run into, is that when the check scans for applicable MIB, it may not find the one for your systems.
The qlogic_sanbox ships that check oid(“.1.3.6.1.2.1.1.2.0”) for “.1.3.6.1.4.1.3873.1.8” and “.1.3.6.1.4.1.3873.1.14”.
My 5802 starts with “.1.3.6.1.4.1.3873.1.9”
I copied the check to ~/local/share/check_mk/checks/ and add my MIB value, and the checks started working.
From: checkmk-en checkmk-en-bounces@lists.mathias-kettner.de
On Behalf Of Andreas Döhler
Sent: Monday, September 23, 2019 1:52 PM
To: marco checl-mk marcocheckmk2005@gmail.com
Cc: checkmk-en@lists.mathias-kettner.de checkmk-en@lists.mathias-kettner.de
Subject: Re: [Check_mk (english)] SNMP v2c issue on qlogic sanbox devices
Hi Marco,
this is a correct behavior. If there are no checks for your device available, then you will only see the general checks like interface and SNMP info.
What you should do first is. Use the actual CheckMK version and test if there are some more information available on your device.
For the fiber channel ports it is also possible to adjust the “Network and switch port discovery” rule. There you can define the interface type the system should discover.
But if this is are “normal” SAN switch then the fiber channel ports should be automatically found.
Best regards
Andreas
Am Mo., 23. Sept. 2019 um 18:10 Uhr schrieb marco checl-mk marcocheckmk2005@gmail.com:
Dear All,
We are trying to monitor qlogic sanbox devices via SNMP. If I do a manual snmpwalk or bulksnmpwalk , I can see a lot of information but when I configure it in check mk it only shows few checks like:
interface
SNMP info
Check mk
It does not show any information about Fibre channel port , temperature sensors etc but I can manually get the OID’s value.
Has anybody else faced this problem?
We are using checkmk 1.2.6p15.
checkmk-en mailing list
https://lists.mathias-kettner.de/cgi-bin/mailman/listinfo/checkmk-en
