I got it working.
This is my config
In Main.mk
extra_host_conf[“notes”] = [
( "latlng: 52.137051,4.6296" , ["ky"], ALL_HOSTS ),
( "latlng: 52.137051,4.6296" , ["lr"], ALL_HOSTS ),
( "latlng: 52.129695,4.659061" , ["adsl"], ALL_HOSTS ),
( "latlng: 52.129695,4.659060" , ["sh-core-01"], ALL_HOSTS ),
In my config.php
<?php $nagios_cfg_file = "/usr/local/nagios/etc/nagios.cfg"; $nagios_status_dat_file = "/usr/local/nagios/var/status.dat"; $nagmap_map_centre = '52.129576,4.659226'; $nagmap_map_zoom = 14; $nagmap_bubble_links = 0; ###do not edit below unless you know what you are doing ###this is a special file, which is only available on a special installations of Moire WiFI controller system developed by the same folks who develop NagMap - give us a shout if you are in a p hase of implementing municipal, or any other type of wifi network :) we might be at your help! include("moire.php"); ?>And this works.
Eikelenboom, Hans
Servicebeheer en Beleid - ICT Beheer
Gemeente Alphen aan den Rijn
Stadhuisplein 1, , 2405 SH, Alphen aan den Rijn
T 465547 | M | F
E
HEikelenboom@alphenaandenrijn.nl | I
W http://www.alphenaandenrijn.nl
P ** * Please consider the environment before printing this e-mail***
Werkdagen: Ma,Di,Wo en Vr
Van: Grégory TRELAT [mailto:gtrelat@ville-saintdie.fr]
Verzonden: woensdag 12 september 2012 10:28
Aan: Eikelenboom, Hans
Onderwerp: Re: [SPAM ZIMBRA][Check_mk (english)] Nagmap in Check_mk.
hi,
I’m interested in this feature too.
I tried too add manually the notes field in check_mk_objects.cfg, but in nagstat i can’t see bubbles.
check_mk_objects.cfg :
define host {
host_name ADSL_BOX_1
use check_mk_host
address 192.168.XX.X
_TAGS ping wato /wato/reseau_mairie/fais/
_FILENAME /wato/reseau_mairie/fais/hosts.mk
hostgroups FAI
contact_groups admins
notification_interval 5
alias ADSL 8M SFR
first_notification_delay 5
notes latlng: 48.287554,6.947786
my nagmap config.php :
<?php $nagios_cfg_file = "/usr/local/nagios/etc/conf.d/check_mk_objects.cfg"; $nagios_status_dat_file = "/usr/local/nagios/var/status.dat"; #$nagmap_map_centre = '57.1633,-2.127'; $nagmap_map_centre = '48.287554,6.947786'; $nagmap_map_zoom = 18; $nagmap_bubble_links = 1; include("moire.php"); ?>Any idea ?
Grégory Trélat
Service Informatique
Mairie de Saint-Dié-des-Vosges
De: “Hans Eikelenboom” Heikelenboom@alphenaandenrijn.nl
À: checkmk-en@lists.mathias-kettner.de
Envoyé: Lundi 10 Septembre 2012 16:21:15
Objet: [SPAM ZIMBRA][Check_mk (english)] Nagmap in Check_mk.
I need to integrated nagmap into check_mk.
How can I make notes in check_mk and so that it is visible in check_mk_objects.
Like this
define host {
host_name Sansw1
use check_mk_host
address x.x.x.x
_TAGS snmp
hostgroups check_mk
contact_groups windows_groep
alias Sansw1
notes this is a note
Or this
define hostextinfo{
host_name Sansw1
notes this a note
Eikelenboom, Hans
T 465547 | M | F
E
checkmk-en mailing list
