I have been thoroughly reading the checkmk documentation which is great. However, I am struggling with creating a special agent. The goal is to use the python request library to query various api. For example, a CheckPoint Security Management appliance. I was wondering if you could help get me started for example, how to create a very basic special agent?
However, I cannot see this in the webgui wato under host and service
parameters->datasource programs
How do I enable it and how do I tell a host to use it?
Thanks
Robert
Sent from my iPhone
Hi Robert,
a special agent consists of two parts minimal.
First part is the special agent producing and formatting the raw data.
The second part is the check who is then transforming your data to check
results.
A good and small example is the Fritzbox routers. agent_fritzbox
The check for the output of this special agent is then the "fritz" check.
This is what the "Individual program call instead of agent access" is for I
think. Just put in /path/to/your/program and maybe some arguments like
hostname or what have you.
