[Check_mk (english)] Start at boot on CentOS7
Anyone else having problems with start on boot under CentOS 7?
Most stuff has been switched to systemctl (jury is out on my opinion of this), but omd still exists in /etc/init.d and a link in /etc/rc3.d (managed by chkconfig).
[root@host ~]# chkconfig --list omd
Note: This output shows SysV services only and does not include native
systemd services. SysV configuration data might be overridden by native
systemd configuration.
  If you want to list systemd services use 'systemctl list-unit-files'.
  To see services enabled on particular target use
  'systemctl list-dependencies [target]'.
omd 0:off 1:off 2:on 3:on 4:on 5:on 6:off
[root@host ~]#
service omd start or /etc/init.d/omd start after sudo’ing to root starts it up just fine.
Thank you,
Lance
Hey,
I had the same problem.
I know it sounds really strange, but for me creating a new rc script in init.d which it isn’t a symbolic link worked.
Didn’t tried to start omd via a system unit.
Hope it helps.
N.
From: checkmk-en-bounces@lists.mathias-kettner.de [mailto:checkmk-en-bounces@lists.mathias-kettner.de]
On Behalf Of Lance Tost
Sent: mercoledì 29 luglio 2015 19:39
To: checkmk-en checkmk-en@lists.mathias-kettner.de
Subject: [Check_mk (english)] Start at boot on CentOS7
[root@host ~]#
Thank you,
Lance
Yep, that worked. Seems like an OS bug, but I can’t find any other reports of it.
At first I just copied /omd/versions/default/share/omd/omd.init to /etc/init.d/omd. But that would mean I would need to remember to update it when I update omd. So instead, in the /etc/init.d/omd copy, I just replaced the case statement with a call to
/omd/versions/default/share/omd/omd.init $* so the init.d script will never need to be updated.
Thank you,
Lance Tost
lance.tost@key-stone.com
Sr. Network Administrator
Keystone Automotive Operations, Inc.
Sent: Thursday, July 30, 2015 2:54 AM
To: Lance Tost; checkmk-en
Subject: RE: Start at boot on CentOS7
Hey,
Hope it helps.
N.
Nicolas Tallarico |
Area Sistemi
Via Dante, 6 - 21052 Busto Arsizio (VA)
Tel: +39 0331357585
Fax: +39 0331622869
[root@host ~]#
Thank you,
Lance
For me, everything works well. Starting centos7, you have to use
systemctl :
Enable the service at boot :
systemctl enable omd
Start the service :
systemctl start omd
Status check
systemctl status omd
On 07/30/2015 03:38 PM, Lance Tost
wrote:
    Yep, that worked.  Seems like an OS bug, but I can't find any
call to /omd/versions/default/share/omd/omd.init $* so the
          Thank you,
          Lance Tost
Tallarico Nicolas Thursday, July 30, 2015 2:54 AM
Hey,
            I had
the same problem.
            I know
            Didn’t
            Hope
it helps.
N.
Nicolas Tallarico |
Area Sistemi
Busto Arsizio (VA)
              Tel:  +39 0331357585
              Fax: +39 0331622869
Lance Tost
checkmk-en
on CentOS7
by chkconfig).
include native
‘systemctl list-unit-files’.
5:on 6:off
            [root@host ~]#
                    Thank you,
                    Lance
checkmk-en mailing list
We’ll meet in Munich for the 2nd Check_MK Conference!
Book your place now and be part of it.
October 18th-20th, 2015
nicolas.tallarico@reti.it
Sent:
To:
Subject:checkmk-en-bounces@lists.mathias-kettner.demailto:checkmk-en-bounces@lists.mathias-kettner.deOn Behalf Of
Sent:
To:checkmk-en@lists.mathias-kettner.de
**Subject:**checkmk-en@lists.mathias-kettner.dehttp://lists.mathias-kettner.de/mailman/listinfo/checkmk-enhttp://mathias-kettner.com/conference
On mine, I get this and it won’t start unless I create a script (not symlink) in /etc/init.d.
[root@host ~]# systemctl is-enabled omd
omd.service is not a native service, redirecting to /sbin/chkconfig.
Executing /sbin/chkconfig omd --level=5
enabled
Doing an enable again anyway gives me this:
[root@host ~]# systemctl enable omd
Executing /sbin/chkconfig omd on
The unit files have no [Install] section. They are not meant to be enabled
using systemctl.
Possible reasons for having this kind of units are:
  1. A unit may be statically enabled by being symlinked from another unit’s
    .wants/ or .requires/ directory.
  2. A unit’s purpose may be to act as a helper for some other unit which has
    a requirement dependency on it.
  3. A unit may be started when needed via activation (socket, path, timer,
    D-Bus, udev, scripted systemctl call, …).
    [root@host ~]#
Thank you,
Lance
Sent: Monday, August 3, 2015 4:55 PM
To: Lance Tost; Tallarico Nicolas; checkmk-en
Subject: Re: [Check_mk (english)] Start at boot on CentOS7
For me, everything works well. Starting centos7, you have to use systemctl :
Start the service :
systemctl start omd
Status check
Thank you,
Lance Tost
Hey,
Hope it helps.
N.
Nicolas Tallarico |
Area Sistemi
Tel: +39 0331357585
Fax: +39 0331622869
To: checkmk-en
[root@host ~]#
Thank you,
Lance
[http://lists.mathias-kettner.de/mailman/listinfo/checkmk-en](https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.mathias-2Dkettner.de_mailman_listinfo_checkmk-2Den&d=AwMF-g&c=rxuyg758I4Zd3CDHNny_Hw&r=IG1JnIFZjjAeb-dpz2SPNF_6BaSzaPzu56FYglLqpI0&m=NYFe1ZNHq2opg-CShAWzv3ZtgcGZnSwIfmvWMtEjGvI&s=2ZTQwzQwY4jPKLVT0pPHXDlBIMCqfs99U2o5oKqxFMA&e=)
[http://mathias-kettner.com/conference](https://urldefense.proofpoint.com/v2/url?u=http-3A__mathias-2Dkettner.com_conference&d=AwMF-g&c=rxuyg758I4Zd3CDHNny_Hw&r=IG1JnIFZjjAeb-dpz2SPNF_6BaSzaPzu56FYglLqpI0&m=NYFe1ZNHq2opg-CShAWzv3ZtgcGZnSwIfmvWMtEjGvI&s=SrvYqqXz1TBVAqt4Jt0b7XUMgElI7co0u7BuAjeiQKA&e=)
