Hello Team,
Currently I am getting alerts via mail based on IP address can i have it along with host name or tag name if it so.
Can you please guide me how to configure it.
Currently I receiving alerts via mails
*** PROBLEM *** IPaddress / Check_MK is CRITICAL
Regards,
Pradeep
Pradeep,
if you did not change the defaults in global settings I'd assume you
configured your hosts' hostname as their IPs, right?
Better choose the "real" hostname and set IP explicitely if needed.
HTH,
Marcel
2013/11/6 Pradeep Kns <knspradeep.blogs@gmail.com>:
Hello Team,
Regards,
Pradeep
checkmk-en mailing list
Marcel,
Thanks for the update it is working after defining host name on /etc/hosts as we dont have dns in our environment.
Regards,
Pradeep
On Wed, Nov 6, 2013 at 7:32 PM, Marcel Schulte schulte.marcel@gmail.com wrote:
Pradeep,
if you did not change the defaults in global settings I’d assume you
configured your hosts’ hostname as their IPs, right?
Better choose the “real” hostname and set IP explicitely if needed.
HTH,
Marcel
2013/11/6 Pradeep Kns knspradeep.blogs@gmail.com:
Hello Team,
Regards,
Pradeep
