[Check_mk (english)] Unable to navigate multisite 1.2.5i6
Hi everybody,
After upgrading from 1.2.5i5p4, i lost the ability to navigate on multisite.
i tried copying files (as advised in Migration to 1.2.5i6 Internal change: view filters moved to visuals If you have defined custom filters for your Multisite views, you need to move
the files containing the filters from share/check_mk/web/plugins/views to share/check_mk/web/plugins/visuals. ) to no avail, not even restarting the machine, or reinstalling CMK (and then restoring backup).
Everything else is working, but of course i cannot use WATO to manage the platform.
I cannot even downgrade…
It is all garbled to navigate or scroll with IE, FF, or Chrome. (Vista 32bit)
i attach a screenshot.
Thanks a lot.
Hi everybody,
i tried copying files (as advised in Migration to 1.2.5i6 Internal change: view filters moved to visuals If you have defined custom filters for your Multisite views, you need to move the files containing the filters from share/check_mk/web/plugins/views to share/check_mk/web/plugins/visuals. ) to no avail, not even restarting the machine, or reinstalling CMK (and then restoring backup).
I cannot even downgrade...
the new css and js files are referenced differently. I got it to work via:
cd /omd/sites/$YOURSITENAME/local/share/check_mk/web/htdocs/js;
for x in *.js;do ln -s $x $(basename $x .js)-1.2.5i6p4.js ;done
and the same for the css files, Updating check_mk this way seems to
work but there is the risk outlined here:
https://www.mail-archive.com/checkmk-en@lists.mathias-kettner.de/msg07225.html
What will you do at the next omd upgrade ?
Regards,
Tom.
Thanks a lot.
AVISO DE CONFIDENCIALIDADE - PRIVACIDADE
Esta mensagem e eventuais ficheiros anexados podem conter informa??o confidencial, destinando-se apenas para uso dos seus destinat?rios. Se recebeu indevidamente esta
mensagem, agradecemos que nos informe, que n?o fa?a uso, copie ou divulgue a mesma e que proceda de imediato ? sua destrui??o. Obrigado
CONFIDENTIALITY NOTICE - PRIVACY
This message and attached files, may contain confidential information, and is intended only for the individual(s) named. If you received this message and are not in the named
addressee, please notify the sender immediately, and don't disseminate, distribute or copy this e-mail. Please delete this e-mail from your system. Thank you.
checkmk-en mailing list
Please avoid sending me Word or PowerPoint attachments.
See We Can Put an End to Word Attachments - GNU Project - Free Software Foundation
and MS-Word is {Not} a document exchange format
