I want to use Check_mk just as a graphing tool like I do with Cacti/Munin.
Do you have any idea if it is possible?
Best,
Benjamin Henrion <bhenrion at ffii.org>
FFII Brussels - +32-484-566109 - +32-2-4148403
"In July 2005, after several failed attempts to legalise software
patents in Europe, the patent establishment changed its strategy.
Instead of explicitly seeking to sanction the patentability of
software, they are now seeking to create a central European patent
court, which would establish and enforce patentability rules in their
favor, without any possibility of correction by competing courts or
democratically elected legislators."
I think it's possible, but you would change the source code to make this work, you have make to all checks stay "OK" state
Why not using Cacti or Minin?!
PS.: Correct me if I'm Wrong.
Best,
checkmk-en mailing list
At.
Italo Santos
okdokk@gmail.com
Check_mk in combination with omd should be perhaps what you are looking for.
Ralf
Ralf Prengel
Manager
Customer Care
Comline AG
Hauert 8
D-44227 Dortmund/Germany
Fon +49 231 97575 904
Fax +49 231 97575 257
Mobil +49 151 10831 157
EMail Ralf.Prengel@comline.de
www.comline.de Vorstand Stephan Schilling, Erwin Leonhardi Aufsichtsrat Dr. Franz Schoser (Vorsitzender) HR Dortmund B 14570 USt.-ID-Nr. DE 124727422
Für die Erstellung unserer Dokumente benutzen wir die Produkte aus dem Microsoft Office 2007 Paket.
Sollte sich ein Anhang in der Mail befinden, der mit einer älteren Office Version nicht geöffnet werden kann,
installieren Sie bitte das Compatibility Pack für Office 2007.
http://www.microsoft.com/downloads/details.aspx?FamilyID=941b3470-3ae9-4aee-8f43-c6bb74cd1466&DisplayLang=de
Am 04.04.2011 10:58, schrieb Benjamin Henrion:
Best,
I'd second the OMD recommendation. The OMD pre-packaged versin of check_mk (+ all the rest) was quite easy to set up, and gets us close to what I was already covering with munin. We still use munin, too, though. Munin is better for side-by-side comparisons. But munin has some serious performance issues once it scales.
Best,
