I don’t think this is possible unless your RAID controller has its’ own dedicated NIC for monitoring (some Areca cards
do, probably more).
The best advice I found is to monitor the RAC/iLO module if you have it. This is only useful if you use a RAID controller
that is supported and monitored by the RAC/iLO module.
FYI: this problem with VMware is the same whatever monitoring tool you use. I know Dell servers with ESXi can be monitored with Dell OpenManage, but that product doesn’t use SNMP for monitoring ESXi hosts - I think it uses WSMan.
Arno Wijnhoven
Why not monitor via the management board ( DRAC, iLO, etc. )? This is what I do for my VMware hosts since as you mentioned, it doesn’t present itself via VMware. This works just fine. I can send you some screenshots
of the data I see if that helps.
Thanks.
Jon Wolberg
Infrastructure Systems Administrator, IU
Phone**:** (800)726-9891 | Direct: (858)275-2569
Email**:** jon.wolberg@iugroup.com Web:
www.iugroup.com
CONFIDENTIALITY STATEMENT: This message is intended only for the addressee and may contain information that is confidential or privileged. Unauthorized use is strictly prohibited and may be unlawful.
If you are not the intended recipient, or the person responsible for delivering to the intended recipient, you should not read, copy, disclose or otherwise use this message, except for the purpose of delivery to the addressee. If you have received this email
in error, please delete it and inform the sender immediately via email.
I strive to always deliver excellent customer service. I encourage you to provide your comments directly to my manager at
shamus.sayed@iugroup.com simply by clicking his name.
From: checkmk-en <checkmk-en-bounces@lists.mathias-kettner.de >
on behalf of Ben Shade benjamin_shade@uk.ibm.com**
Sent:** Wednesday, August 1, 2018 9:40:58 AM**
To:** checkmk-en@lists.mathias-kettner.de**
Subject:** [Check_mk (english)] VMware 6.5 and monitoring RAID
Had a quick look around, but not a good look so may have missed this, so please excuse any obvious answers I have missed.
Looking to monitor the underlying RAID (AVAGO/LSI) on an (well multiple) VMware ESXi box. Have the SMIS all set up for VMWare and it is reporting to VMware client ok.
esx_vsphere including hardware sensors report fine in check_mk, but looking in detail the output this does not include the RAID, or any storage hw info (not unexpected).
Obviously this is deep specific drivers etc, so not expecting anything, but is there a way to monitor these RAID through VMWare using check_mk?
Reasoning is that this is a remote box, with VMWare on it, but no SNMP info on the RAID or disks at low level, and last week one started to fail - now fixed - but now wanting to monitor more closely so was hoping for SNMP but none available, so at higher level
was hoping VMware could do it - it can just about - so now hoping check_mk can read what VMWare can now see
Thanks
Ben
Unless stated otherwise above:
IBM United Kingdom Limited - Registered in England and Wales with number 741598.
Registered office: PO Box 41, North Harbour, Portsmouth, Hampshire PO6 3AU
