[Check_mk (english)] VMware vSphere plugin no datastores
Hello
Using the vSphere plugin with some vCenter 6.5 appliances, no Datastore checks are being added
Looking at the diagnostic output, the vCenters are providing DS info. The check_mk version is very old, so perhaps the plugin can’t understand vCenter 6.5 ?
Thanks in advance for any advice
Cheers
Garth
Zitat von "Garth Horsburgh [DATACOM]" <GarthH@datacom.co.nz>:
Hello
Looking at the diagnostic output, the vCenters are providing DS info. The check_mk version is very old, so perhaps the plugin can't understand vCenter 6.5 ?
which Version of check-mk are you using?
Is it possible for you to install a testsite with the latest 1.4 Version?
A standard check using the ESX datasource works fine here.
Ralf
I can also vouch it’s working fine for me as well on 1.4.0p34 and many versions prior to that.
Did you make sure to add your hostname or IP for your vCenter in the ESX Datastores plugin?
Jon Wolberg
Infrastructure Systems Administrator,
IU
Phone**:** (800)726-9891
| Direct: (858)275-2569
Email**:**
jon.wolberg@iugroup.com
Web:
www.iugroup.com
CONFIDENTIALITY STATEMENT: This message is intended only for the addressee and may contain information that is confidential or privileged. Unauthorized use is strictly prohibited and may be unlawful. If you are not the intended recipient,
or the person responsible for delivering to the intended recipient, you should not read, copy, disclose or otherwise use this message, except for the purpose of delivery to the addressee. If you have received this email in error, please delete it and inform
the sender immediately via email.
I strive to always deliver excellent customer service. I encourage you to provide your comments directly to my manager at
shamus.sayed@iugroup.com simply by clicking his name.
From: checkmk-en checkmk-en-bounces@lists.mathias-kettner.de on behalf of Ralf Prengel ralf.prengel@rprengel.de
Sent: Sunday, August 5, 2018 10:41:52 PM
Subject: Re: [Check_mk (english)] VMware vSphere plugin no datastores
Zitat von “Garth Horsburgh [DATACOM]” GarthH@datacom.co.nz:
Hello
Ralf
checkmk-en mailing list
Hi Guys
Thanks for the reply, the check_mk running on this customer is 1.2.8p8
We had problems compiling newer versions from source so we are planning to move to the packaged version in the future.
Jon can you clarify ‘ Did you make sure to add your hostname or IP for your vCenter in the ESX
Datastores plugin?’
Do you mean a ‘ESX Datastores (used space and growth)’ rule? Yes I have a global rule in place that should apply to all vCenters/VCSAs
Cheers
Garth
On Behalf Of Jon Wolberg
Sent: Tuesday, 7 August 2018 4:44 AM
To: Ralf Prengel ralf.prengel@rprengel.de; checkmk-en@lists.mathias-kettner.de
Jon Wolberg
IU
Phone**:**
(800)726-9891 | Direct: (858)275-2569
Email**:**
Web:
www.iugroup.com
is confidential or privileged. Unauthorized use is strictly prohibited and may be unlawful. If you are not the intended recipient, or the person responsible for delivering to the intended recipient, you should not read, copy, disclose or otherwise use this
message, except for the purpose of delivery to the addressee. If you have received this email in error, please delete it and inform the sender immediately via email.
to my manager at shamus.sayed@iugroup.com simply by clicking his name.
From: checkmk-en <checkmk-en-bounces@lists.mathias-kettner.de >
Hello
Ralf
Has this ever worked for you?
Can you confirm you have the ‘Datastores’ check box checked in the Special Agent config? (it is under
Retrieve information about…)
On Mon, Aug 6, 2018 at 2:34 PM Garth Horsburgh [DATACOM] GarthH@datacom.co.nz wrote:
Hi Guys
Datastores plugin?’
Cheers
Garth
Jon Wolberg
IU
Phone**:**
Email**:**
Web:
www.iugroup.com
Hello
Ralf
Yes the ‘Check state of VMware ESX via vSphere’ is configured to query vCenter, with correct user details and retrieve info on Datastores
is checked
Diagnostic output of the host is as expected and I can see datastore info
Eg
<<<esx_vsphere_datastores:sep(9)>>>
[SSD_dataStore]
accessible true
capacity 2880312442880
freeSpace 191130238976
The problem seems to be esx_vsphere_datastores plugin is not parsing the output and adding service check
Hi Guys
Jon can you clarify ‘Did you make sure to add your hostname or IP for your vCenter in the ESX Datastores plugin?’
Cheers
Garth
Jon Wolberg
IU
Phone**:**
Email**:**
Web:
www.iugroup.com
may be unlawful. If you are not the intended recipient, or the person responsible for delivering to the intended recipient, you should not read, copy, disclose or otherwise use this message, except for the purpose of delivery to the addressee. If you have
Hello
Ralf
Further to this, yes I have another vcenter (6.0) that adds datastore checks no problem.
Comparing the agent output, the format is identical so it doesn’t look like anything changed with 6.5
On Behalf Of Garth Horsburgh [DATACOM]
Sent: Tuesday, 7 August 2018 9:46 AM
To: Paul Dott pauldott@gmail.com
is checked
Eg
[SSD_dataStore]
accessible true
Sent: Tuesday, 7 August 2018 9:38 AM
To: Garth Horsburgh [DATACOM] GarthH@datacom.co.nz
Cc: jon.wolberg@iugroup.com;
Hi Guys
Cheers
Garth
Jon Wolberg
IU
Phone**:**
Email**:**
Web:
www.iugroup.com
Hello
Ralf
Hi all
Looks like it was a rogue rule, I moved the VCSA’s to another folder and created a new host tag/rule for vcenter 6.5 and now it is
now working.
Cheers
Garth
Sent: Tuesday, 7 August 2018 10:14 AM
To: Garth Horsburgh [DATACOM] GarthH@datacom.co.nz; Paul Dott pauldott@gmail.com
Subject: RE: [Check_mk (english)] VMware vSphere plugin no datastores
is checked
Eg
[SSD_dataStore]
accessible true
Hi Guys
Cheers
Garth
Jon Wolberg
IU
Phone**:**
Email**:**
Web:
www.iugroup.com
Hello
Ralf
