[Check_mk (english)] WATO on master, configure host on slave??
Trying to rebuild one master and seven slave servers to all use WATO. One thing I haven't quite figured out yet is once the master is up and running with a slave server connected, how do I define a new host and designate that it should be managed at one particular slave?
Master has the web interface
Slave1 is connected via multisite
Slave2 is connected via multisite
If I configure a host from the master where do I configure that host should be monitored by slave2? So far I haven't seen any option while configuring hosts to set this.
check_mk 1.2.6p12 installed via omd-1.31.20160708
Stephen Berg
Systems Administrator
NRL Code: 7320
Office: 228-688-5738
stephen.berg.ctr@nrlssc.navy.mil
Properties of host <urhost>
Basic settings -> Monitored on site
(can be configured in folder properties if ur folders are organized by location or site)
Found the "Basic settings" area, but I only see:
Permissions
Alias
IP address
SNMP Community
Parents
Is there a config option somewhere that I missed that'll turn on the "Monitored on site" option?
Stephen Berg
NRL Code: 7320
