cmk -D hostname shows no issues, CRITs, alarms, nor does connecting to the VMware host and checking out the health. Everything is green across the board.
Documentation states: CRIT if vsphere reports overall state of red or grey or if the ESX host is in power state poweredOff
We can see it’s not powered off and I can’t find any health issues whatsoever.
This state is reported from the ESX host them self or your vCenter. It is possible to run the special agent command with the addition if “–tracefile ” option to get the raw response from your queried system.
With this trace file you can check for the health output.
There inside should be some text about the reported issue.
I am going to investigate this some more. Thanks very much for this information because I haven’t seen this on any of my systems before. I’ll see what I can find and post back.
output.
issue.
cmk -D
across the board.
poweredOff
We can see
whatsoever.
output.
issue.
cmk -D
across the board.
poweredOff
We can
whatsoever.
