I have two Windows 2016 servers (for RDP terminal access) with installed Check_MK agent and with the check_mk.ini containing
[winperf]
counters = Terminal Services:ts_sessions
It works on one server but not on the other one. The configuration in Check_MK is the same. The .ini is the same. But the winperf_ts_session output (via ‘cmk -d’) is only available on one of the servers.
I already tried it with the performance counter number (instead of the name above) retrieved by the ‘lodctr’ command but this also won’t work. I also restarted the Check_MK service…
service…
[winperf]
# Select counters to extract. The following counters
# are needed by checks shipped with check_mk.
# counters = 10332:msx_queues
counters = 638:tcp_conn
counters = 3198:ts_sessions
counters = 1920:ts_sessions
The 3198 is the Winperf Counter until 2008R2, the 1920 is the one for 2012 onwards.
Copy it and restart the agent, should work, at least it does on all ~3000 Windows Servers in my responsibility:-)
[winperf]
service…
What else can I check?
Regards
Sebastian
This electronic transmission (and any attachments thereto) is intended solely for the use of the addressee(s). It may contain confidential or legally privileged information. If you are not the intended recipient of this message, you must delete it immediately and notify the sender. Any unauthorized use or disclosure of this message is strictly prohibited. Faurecia does not guarantee the integrity of this transmission and shall therefore never be liable if the message is altered or falsified nor for any virus, interception or damage to your system.
