Hello Everyone.
I’m trying to monitor zfs pool usage and I’m having some trouble on how check_mk does this.
I have omd installed and the check_mk is reporting zpool status only. I would like it to show the usage statistics of pools. I have been searching for a documentation on how to do this and most of the references I found is too vague for me to understand.
Could someone point me to how I can have check_mk to show disk usage/trend? What I found on this page https://mathias-kettner.de/checkmk_check_zfsget.html was not helpful for me to understand.
The systems are outputting zfs related information.
rootfs rootfs 1911216768 1049216 1910167552 1% /
udev devtmpfs 65992920 4 65992916 1% /dev
rpool name rpool -
rpool quota 0 default
rpool used 5714717696 -
rpool available 1956011594752 -
rpool mountpoint / local
rpool type filesystem -
rpool/ROOT name rpool/ROOT -
rpool/ROOT quota 0 default
rpool/ROOT used 1147936768 -
rpool/ROOT available 1956011594752 -
rpool/ROOT mountpoint none local
rpool/ROOT type filesystem -
rpool/ROOT/ubuntu name rpool/ROOT/ubuntu -
rpool/ROOT/ubuntu quota 0 default
rpool/ROOT/ubuntu used 1147906048 -
rpool/ROOT/ubuntu available 1956011594752 -
rpool/ROOT/ubuntu mountpoint / local
rpool/ROOT/ubuntu type filesystem -
rpool/ROOT/ubuntu@install name rpool/ROOT/ubuntu@install -
rpool/ROOT/ubuntu@install quota - -
rpool/ROOT/ubuntu@install used 73430016 -
rpool/ROOT/ubuntu@install available - -
rpool/ROOT/ubuntu@install mountpoint - -
rpool/ROOT/ubuntu@install type snapshot -
rpool/swap name rpool/swap -
rpool/swap quota - -
rpool/swap used 4565762048 -
rpool/swap available 1960544232960 -
rpool/swap mountpoint - -
rpool/swap type volume -
rpool/var name rpool/var -
rpool/var quota 0 default
rpool/var used 63488 -
rpool/var available 1956011594752 -
rpool/var mountpoint /var inherited from rpool
rpool/var type filesystem -
rpool/var/tmp name rpool/var/tmp -
rpool/var/tmp quota 0 default
rpool/var/tmp used 32768 -
rpool/var/tmp available 1956011594752 -
rpool/var/tmp mountpoint /var/tmp inherited from rpool
rpool/var/tmp type filesystem -
tank name tank -
tank quota 0 default
tank used 9218217305277 -
tank available 27652936080195 -
tank mountpoint /tank default
tank type filesystem -
[df]
rpool/ROOT/ubuntu zfs 1911216768 1049216 1910167552 1% /
rpool/var/tmp zfs 1910167552 0 1910167552 0% /var/tmp
tank zfs 36006784512 9001964160 27004820352 26% /tank
<<<zpool_status>>>
all pools are healthy
Thanks in advance!
