I have a question regarding the default thresholds that CMK use.
I see CMK use a standard for the RTA and Packet loss configurations (RTA 200ms/500ms Packet loos 80%/100%), you can see these thresholds clicking on the name of the host:
In this section, when i click on the host icons part to go to the “Parameters for this host”, i can´t create a new rule to modify the current thresholds, i only can see the main configurations for this host like other kind of rules, but i don´t know if i can change this thresholds:
Even if i activate the PING service check, and configure another thresholds for the rta and packet loos, cmk use both parameters and i don´t want this PING check activated, i just want use the standard configuration.
try the following rule:
This should have the desired effect.
However, this may be different in the Enterprise versions, but i assume from your tags for this topic that you are using the RAW edition.
Hope that helps.
Hi, I am struggling with adapting the RTA of the PING service. I have a solar inverter which somehow shows in check_mk crazy roundtrip times (in the screenshot below 1.294.133ms!!!).
For testing, I put the solar inverter into the networking segment “WAN (high latency)” and changed the host check rule accordingly:
-w 7540000.00,80% -c 8540000.00,100%
As you can see, those thresholds are not applied by the rule - it seems that 255000ms is the maximum that can be used:
next time, please open a new topic this one has been solved -
I guess it’s possible that there is a maximum value that is set as the threshold, what I’m wondering is: maybe there is a tcp port you could check (web interface or something like that?) that responds better than the ping?
