I am trying to monitor an old production host that is running multiple JBoss 5.1 instances. Each instance in running on different IP on host. I have fully running agent (manually installed) and jolokia plugin (.war) deployed on all instances. RHEL5.7 by default comes with python 2.4x. That is too old. I installed python 2.6.8 from EPEL. Upon executing mk_jolokia_2 plugin I get following errors:
./mk_jolokia_2.py
<<<jolokia_info:sep(0)>>>
File “./mk_jolokia_2.py”, line 623, in
main()
File “./mk_jolokia_2.py”, line 617, in main
query_instance(instance)
File “./mk_jolokia_2.py”, line 521, in query_instance
write_section(‘jolokia_info’, generate_jolokia_info(inst))
File “./mk_jolokia_2.py”, line 197, in write_section
for line in iterable:
File “./mk_jolokia_2.py”, line 540, in generate_jolokia_info
data = fetch_var(inst, “version”, “”)
File “./mk_jolokia_2.py”, line 402, in fetch_var
obj = inst.post(data)
File “./mk_jolokia_2.py”, line 365, in post
return validate_response(raw_response)
File “./mk_jolokia_2.py”, line 383, in validate_response
response = raw.json()
TypeError: ‘dict’ object is not callable
Is this a python incompatibility error or mos-configuration error?
My jolokia.cfg has following content (IPs have been replaced):
vi jolokia.cfg
.# Settings for authentication
protocol = “http”
port = “8080”
mode = “basic_preemptive”
suburi = “jolokia”
instance = None
instances = [
.# Front Interface JBoss
“server”:“192.168.9.16”,
.# Backend01 JBoss
“server”:“192.168.9.13”,
.# Backend02 JBoss
“server”:“192.168.9.15”,
Any advice is welcome
Regards,
Olsi
