In addition :
cmk --debug -vvII rancid_nexus
Trying to acquire lock on /omd/sites/lyo2/var/check_mk/crashes/base/16efa592-f15a-11ec-907f-c609533838e6/crash.info
Got lock on /omd/sites/lyo2/var/check_mk/crashes/base/16efa592-f15a-11ec-907f-c609533838e6/crash.info
Releasing lock on /omd/sites/lyo2/var/check_mk/crashes/base/16efa592-f15a-11ec-907f-c609533838e6/crash.info
Released lock on /omd/sites/lyo2/var/check_mk/crashes/base/16efa592-f15a-11ec-907f-c609533838e6/crash.info
File "/omd/sites/lyo2/bin/cmk", line 92, in <module>
File "/omd/sites/lyo2/lib/python3/cmk/base/modes/__init__.py", line 69, in call
return handler(*handler_args)
File "/omd/sites/lyo2/lib/python3/cmk/base/modes/check_mk.py", line 1699, in mode_discover
discovery.commandline_discovery(
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/__init__.py", line 182, in commandline_discovery
_commandline_discovery_on_host(
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/__init__.py", line 249, in _commandline_discovery_on_host
host_labels = analyse_node_labels(
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/_host_labels.py", line 79, in analyse_node_labels
discovered_host_labels=_discover_host_labels(
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/_host_labels.py", line 214, in _discover_host_labels
**_discover_host_labels_for_source_type(
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/_host_labels.py", line 237, in _discover_host_labels_for_source_type
parsed_results = parsed_sections_broker.all_parsing_results(host_key)
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", line 293, in all_parsing_results
return sorted(resolver.resolve_all(parser), key=lambda r: r.section.name)
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", line 203, in <genexpr>
if (res := self.resolve(parser, psn)) is not None
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", line 188, in resolve
if (parsing_result := parser.parse(producer)) is not None:
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", line 104, in parse
if (parsed := self._parse_raw_data(section)) is None
File "/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", line 122, in _parse_raw_data
return section.parse_function(list(raw_data))
File "/omd/sites/lyo2/lib/python3/cmk/base/plugins/agent_based/inventory_docker_container_network.py", line 18, in parse_docker_container_network
return docker.parse(string_table).data
File "/omd/sites/lyo2/lib/python3/cmk/base/plugins/agent_based/utils/docker.py", line 99, in parse
raise ValueError(
ValueError: Expected list of length 2. First element list of 2 strings, second element list of 1 string
cat /omd/sites/lyo2/var/check_mk/crashes/base/16efa592-f15a-11ec-907f-c609533838e6/crash.info
{"time": 1655812977.2687418, "os": "Debian GNU/Linux 11 (bullseye)", "version": "2.1.0p2", "edition": "cre", "core": "nagios", "python_version": "3.9.10 (main, May 11 2022, 22:14:42) \n[GCC 11.2.0]", "python_paths": ["/opt/omd/versions/2.1.0p2.cre/bin", "/omd/sites/lyo2/local/lib/python3", "/omd/sites/lyo2/lib/python3/plus", "/omd/sites/lyo2/lib/python39.zip", "/omd/sites/lyo2/lib/python3.9", "/omd/sites/lyo2/lib/python3.9/lib-dynload", "/omd/sites/lyo2/lib/python3.9/site-packages", "/omd/sites/lyo2/lib/python3"], "id": "16efa592-f15a-11ec-907f-c609533838e6", "crash_type": "base", "exc_type": "ValueError", "exc_value": "Expected list of length 2. First element list of 2 strings, second element list of 1 string", "exc_traceback": [["/omd/sites/lyo2/bin/cmk", 92, "<module>", "exit_status = modes.call(mode_name, mode_args, opts, args)"], ["/omd/sites/lyo2/lib/python3/cmk/base/modes/__init__.py", 69, "call", "return handler(*handler_args)"], ["/omd/sites/lyo2/lib/python3/cmk/base/modes/check_mk.py", 1699, "mode_discover", "discovery.commandline_discovery("], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/__init__.py", 182, "commandline_discovery", "_commandline_discovery_on_host("], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/__init__.py", 249, "_commandline_discovery_on_host", "host_labels = analyse_node_labels("], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/_host_labels.py", 79, "analyse_node_labels", "discovered_host_labels=_discover_host_labels("], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/_host_labels.py", 214, "_discover_host_labels", "**_discover_host_labels_for_source_type("], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/discovery/_host_labels.py", 237, "_discover_host_labels_for_source_type", "parsed_results = parsed_sections_broker.all_parsing_results(host_key)"], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", 293, "all_parsing_results", "return sorted(resolver.resolve_all(parser), key=lambda r: r.section.name)"], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", 203, "<genexpr>", "if (res := self.resolve(parser, psn)) is not None"], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", 188, "resolve", "if (parsing_result := parser.parse(producer)) is not None:"], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", 104, "parse", "if (parsed := self._parse_raw_data(section)) is None"], ["/omd/sites/lyo2/lib/python3/cmk/base/agent_based/data_provider.py", 122, "_parse_raw_data", "return section.parse_function(list(raw_data))"], ["/omd/sites/lyo2/lib/python3/cmk/base/plugins/agent_based/inventory_docker_container_network.py", 18, "parse_docker_container_network", "return docker.parse(string_table).data"], ["/omd/sites/lyo2/lib/python3/cmk/base/plugins/agent_based/utils/docker.py", 99, "parse", "raise ValueError("]], "local_vars": "eydzdHJpY3QnOiBUcnVlLAogJ3N0cmluZ190YWJsZSc6IFtbJ0Bkb2NrZXJfdmVyc2lvbl9pbmZvJywKICAgICAgICAgICAgICAgICAgICd7IlBsdWdpblZlcnNpb24iOiAiMC4xIiwgIkRvY2tlclB5VmVyc2lvbiI6ICI0LjEuMCIsICcKICAgICAgICAgICAgICAgICAgICciQXBpVmVyc2lvbiI6ICIxLjQxIn0nXSwKICAgICAgICAgICAgICAgICAgWyd7IkJyaWRnZSI6ICIiLCAiU2FuZGJveElEIjogJwogICAgICAgICAgICAgICAgICAgJyIyNGNiMTE4ZDY1YWUwNTE3OTQ3NmQ0ODIzOTZhODZiZTUxZTVmOWJmMGZlYWNhYTRlYTUyM2M5Yzc2MjdiOTc5IiwgJwogICAgICAgICAgICAgICAgICAgJyJIYWlycGluTW9kZSI6IGZhbHNlLCAiTGlua0xvY2FsSVB2NkFkZHJlc3MiOiAiIiwgJwogICAgICAgICAgICAgICAgICAgJyJMaW5rTG9jYWxJUHY2UHJlZml4TGVuIjogMCwgIlBvcnRzIjoge30sICJTYW5kYm94S2V5IjogJwogICAgICAgICAgICAgICAgICAgJyIvdmFyL3J1bi9kb2NrZXIvbmV0bnMvMjRjYjExOGQ2NWFlIiwgJwogICAgICAgICAgICAgICAgICAgJyJTZWNvbmRhcnlJUEFkZHJlc3NlcyI6IG51bGwsICJTZWNvbmRhcnlJUHY2QWRkcmVzc2VzIjogJwogICAgICAgICAgICAgICAgICAgJ251bGwsICJFbmRwb2ludElEIjogJwogICAgICAgICAgICAgICAgICAgJyIwOWVkYjc1MjM2ZGViMDVmMjkyNjk3ZDZiOGVhMDFiYWU5YWVmZGVkNTc1NzExNzEwYzVhMzFhNWE2NDNhOTFhIiwgJwogICAgICAgICAgICAgICAgICAgJyJHYXRld2F5IjogIjE3Mi4xNy4wLjEiLCAiR2xvYmFsSVB2NkFkZHJlc3MiOiAiIiwgJwogICAgICAgICAgICAgICAgICAgJyJHbG9iYWxJUHY2UHJlZml4TGVuIjogMCwgIklQQWRkcmVzcyI6ICIxNzIuMTcuMC4xMCIsICcKICAgICAgICAgICAgICAgICAgICciSVBQcmVmaXhMZW4iOiAxNiwgIklQdjZHYXRld2F5IjogIiIsICJNYWNBZGRyZXNzIjogJwogICAgICAgICAgICAgICAgICAgJyIwMjo0MjphYzoxMTowMDowYSIsICJOZXR3b3JrcyI6IHsiYnJpZGdlIjogeyJJUEFNQ29uZmlnIjogJwogICAgICAgICAgICAgICAgICAgJ251bGwsICJMaW5rcyI6IG51bGwsICJBbGlhc2VzIjogbnVsbCwgIk5ldHdvcmtJRCI6ICcKICAgICAgICAgICAgICAgICAgICciNDdiMmViN2E1YjI0ZTUxYzNjYjAwMDNjMmZkZTk0MTg3YWQ5Y2NjZTMwYmZjOTk0NjIxNjU0ZDJkZmJjMTE4YiIsICcKICAgICAgICAgICAgICAgICAgICciRW5kcG9pbnRJRCI6ICcKICAgICAgICAgICAgICAgICAgICciMDllZGI3NTIzNmRlYjA1ZjI5MjY5N2Q2YjhlYTAxYmFlOWFlZmRlZDU3NTcxMTcxMGM1YTMxYTVhNjQzYTkxYSIsICcKICAgICAgICAgICAgICAgICAgICciR2F0ZXdheSI6ICIxNzIuMTcuMC4xIiwgIklQQWRkcmVzcyI6ICIxNzIuMTcuMC4xMCIsICcKICAgICAgICAgICAgICAgICAgICciSVBQcmVmaXhMZW4iOiAxNiwgIklQdjZHYXRld2F5IjogIiIsICJHbG9iYWxJUHY2QWRkcmVzcyI6ICcKICAgICAgICAgICAgICAgICAgICciIiwgIkdsb2JhbElQdjZQcmVmaXhMZW4iOiAwLCAiTWFjQWRkcmVzcyI6ICcKICAgICAgICAgICAgICAgICAgICciMDI6NDI6YWM6MTE6MDA6MGEiLCAiRHJpdmVyT3B0cyI6IG51bGx9fX0nXSwKICAgICAgICAgICAgICAgICAgWydAZG9ja2VyX3ZlcnNpb25faW5mbycsCiAgICAgICAgICAgICAgICAgICAneyJQbHVnaW5WZXJzaW9uIjogIjAuMSIsICJEb2NrZXJQeVZlcnNpb24iOiAiNC4xLjAiLCAnCiAgICAgICAgICAgICAgICAgICAnIkFwaVZlcnNpb24iOiAiMS40MSJ9J10sCiAgICAgICAgICAgICAgICAgIFsneyJCcmlkZ2UiOiAiIiwgIlNhbmRib3hJRCI6ICcKICAgICAgICAgICAgICAgICAgICciZjBiYWRmYmYzNjc4YTc5N2FhZTNkMjViNjhiNTkxNzI1ZTM0YzliYjEyMTE5MmQ4NWQxM2NiODM2NTMyY2U1ZSIsICcKICAgICAgICAgICAgICAgICAgICciSGFpcnBpbk1vZGUiOiBmYWxzZSwgIkxpbmtMb2NhbElQdjZBZGRyZXNzIjogIiIsICcKICAgICAgICAgICAgICAgICAgICciTGlua0xvY2FsSVB2NlByZWZpeExlbiI6IDAsICJQb3J0cyI6IHt9LCAiU2FuZGJveEtleSI6ICcKICAgICAgICAgICAgICAgICAgICciL3Zhci9ydW4vZG9ja2VyL25ldG5zL2YwYmFkZmJmMzY3OCIsICcKICAgICAgICAgICAgICAgICAgICciU2Vjb25kYXJ5SVBBZGRyZXNzZXMiOiBudWxsLCAiU2Vjb25kYXJ5SVB2NkFkZHJlc3NlcyI6ICcKICAgICAgICAgICAgICAgICAgICdudWxsLCAiRW5kcG9pbnRJRCI6ICcKICAgICAgICAgICAgICAgICAgICciZTljMWU3ZmVkZWQ3YzE0OWMwN2EyNDllNWM2MTk0MDNhY2JjMTRhMmI4YTJkYWZkNzYyNWJmYjEwZDlmYmNlZSIsICcKICAgICAgICAgICAgICAgICAgICciR2F0ZXdheSI6ICIxNzIuMTcuMC4xIiwgIkdsb2JhbElQdjZBZGRyZXNzIjogIiIsICcKICAgICAgICAgICAgICAgICAgICciR2xvYmFsSVB2NlByZWZpeExlbiI6IDAsICJJUEFkZHJlc3MiOiAiMTcyLjE3LjAuOCIsICcKICAgICAgICAgICAgICAgICAgICciSVBQcmVmaXhMZW4iOiAxNiwgIklQdjZHYXRld2F5IjogIiIsICJNYWNBZGRyZXNzIjogJwogICAgICAgICAgICAgICAgICAgJyIwMjo0MjphYzoxMTowMDowOCIsICJOZXR3b3JrcyI6IHsiYnJpZGdlIjogeyJJUEFNQ29uZmlnIjogJwogICAgICAgICAgICAgICAgICAgJ251bGwsICJMaW5rcyI6IG51bGwsICJBbGlhc2VzIjogbnVsbCwgIk5ldHdvcmtJRCI6ICcKICAgICAgICAgICAgICAgICAgICciZDExNGUyMjA4MmI3Y2ExN2MwYzc3ZmQ1M2EwNTg0MzVhY2VjYzYzNzcyNmRiMGMzNmY4Zjc3YzRlNDFmMDExOCIsICcKICAgICAgICAgICAgICAgICAgICciRW5kcG9pbnRJRCI6ICcKICAgICAgICAgICAgICAgICAgICciZTljMWU3ZmVkZWQ3YzE0OWMwN2EyNDllNWM2MTk0MDNhY2JjMTRhMmI4YTJkYWZkNzYyNWJmYjEwZDlmYmNlZSIsICcKICAgICAgICAgICAgICAgICAgICciR2F0ZXdheSI6ICIxNzIuMTcuMC4xIiwgIklQQWRkcmVzcyI6ICIxNzIuMTcuMC44IiwgJwogICAgICAgICAgICAgICAgICAgJyJJUFByZWZpeExlbiI6IDE2LCAiSVB2NkdhdGV3YXkiOiAiIiwgIkdsb2JhbElQdjZBZGRyZXNzIjogJwogICAgICAgICAgICAgICAgICAgJyIiLCAiR2xvYmFsSVB2NlByZWZpeExlbiI6IDAsICJNYWNBZGRyZXNzIjogJwogICAgICAgICAgICAgICAgICAgJyIwMjo0MjphYzoxMTowMDowOCIsICJEcml2ZXJPcHRzIjogbnVsbH19fSddLAogICAgICAgICAgICAgICAgICBbJ0Bkb2NrZXJfdmVyc2lvbl9pbmZvJywKICAgICAgICAgICAgICAgICAgICd7IlBsdWdpblZlcnNpb24iOiAiMC4xIiwgIkRvY2tlclB5VmVyc2lvbiI6ICI0LjEuMCIsICcKICAgICAgICAgICAgICAgICAgICciQXBpVmVyc2lvbiI6ICIxLjQxIn0nXSwKICAgICAgICAgICAgICAgICAgWyd7IkJyaWRnZSI6ICIiLCAiU2FuZGJveElEIjogJwogICAgICAgICAgICAgICAgICAgJyI3ZmZkMDA1NmMzZTc1ZjhmNjYzZTRjNDM4ODRmMjc0NTkwNmI2YjgwODQ3Yzg0NmNhZmFkMjM0Yjk5ZDdiMGUwIiwgJwogICAgICAgICAgICAgICAgICAgJyJIYWlycGluTW9kZSI6IGZhbHNlLCAiTGlua0xvY2FsSVB2NkFkZHJlc3MiOiAiIiwgJwogICAgICAgICAgICAgICAgICAgJyJMaW5rTG9jYWxJUHY2UHJlZml4TGVuIjogMCwgIlBvcnRzIjoge30sICJTYW5kYm94S2V5IjogJwogICAgICAgICAgICAgICAgICAgJyIvdmFyL3J1bi9kb2NrZXIvbmV0bnMvN2ZmZDAwNTZjM2U3IiwgJwogICAgICAgICAgICAgICAgICAgJyJTZWNvbmRhcnlJUEFkZHJlc3NlcyI6IG51bGwsICJTZWNvbmRhcnlJUHY2QWRkcmVzc2VzIjogJwogICAgICAgICAgICAgICAgICAgJ251bGwsICJFbmRwb2ludElEIjogJwogICAgICAgICAgICAgICAgICAgJyIwZDM5ZDk5OTQ0MTRmNjhjYmFmMzRmNjZiMGFiYjI4MTEzMmU1ZDBiN2E1YzFhNmVjOGVlOWU4YWYyYzgzMDI3IiwgJwogICAgICAgICAgICAgICAgICAgJyJHYXRld2F5IjogIjE3Mi4xNy4wLjEiLCAiR2xvYmFsSVB2NkFkZHJlc3MiOiAiIiwgJwogICAgICAgICAgICAgICAgICAgJyJHbG9iYWxJUHY2UHJlZml4TGVuIjogMCwgIklQQWRkcmVzcyI6ICIxNzIuMTcuMC41IiwgJwogICAgICAgICAgICAgICAgICAgJyJJUFByZWZpeExlbiI6IDE2LCAiSVB2NkdhdGV3YXkiOiAiIiwgIk1hY0FkZHJlc3MiOiAnCiAgICAgICAgICAgICAgICAgICAnIjAyOjQyOmFjOjExOjAwOjA1IiwgIk5ldHdvcmtzIjogeyJicmlkZ2UiOiB7IklQQU1Db25maWciOiAnCiAgICAgICAgICAgICAgICAgICAnbnVsbCwgIkxpbmtzIjogbnVsbCwgIkFsaWFzZXMiOiBudWxsLCAiTmV0d29ya0lEIjogJwogICAgICAgICAgICAgICAgICAgJyI3YmQ1M2VhOGY0NTA0ZDMwZTI4MDc2NTI5M2Y2YWMwMTY3MzBjYTQ2OWIxMTE0N2UzOTA3MTFjNDVkMTA3ZTdkIiwgJwogICAgICAgICAgICAgICAgICAgJyJFbmRwb2ludElEIjogJwogICAgICAgICAgICAgICAgICAgJyIwZDM5ZDk5OTQ0MTRmNjhjYmFmMzRmNjZiMGFiYjI4MTEzMmU1ZDBiN2E1YzFhNmVjOGVlOWU4YWYyYzgzMDI3IiwgJwogICAgICAgICAgICAgICAgICAgJyJHYXRld2F5IjogIjE3Mi4xNy4wLjEiLCAiSVBBZGRyZXNzIjogIjE3Mi4xNy4wLjUiLCAnCiAgICAgICAgICAgICAgICAgICAnIklQUHJlZml4TGVuIjogMTYsICJJUHY2R2F0ZXdheSI6ICIiLCAiR2xvYmFsSVB2NkFkZHJlc3MiOiAnCiAgICAgICAgICAgICAgICAgICAnIiIsICJHbG9iYWxJUHY2UHJlZml4TGVuIjogMCwgIk1hY0FkZHJlc3MiOiAnCiAgICAgICAgICAgICAgICAgICAnIjAyOjQyOmFjOjExOjAwOjA1IiwgIkRyaXZlck9wdHMiOiBudWxsfX19J10sCiAgICAgICAgICAgICAgICAgIFsnQGRvY2tlcl92ZXJzaW9uX2luZm8nLAogICAgICAgICAgICAgICAgICAgJ3siUGx1Z2luVmVyc2lvbiI6ICIwLjEiLCAiRG9ja2VyUHlWZXJzaW9uIjogIjQuMS4wIiwgJwogICAgICAgICAgICAgICAgICAgJyJBcGlWZXJzaW9uIjogIjEuNDEifSddLAogICAgICAgICAgICAgICAgICBbJ3siQnJpZGdlIjogIiIsICJTYW5kYm94SUQiOiAnCiAgICAgICAgICAgICAgICAgICAnIjg5ZDM5NmYzOTAyOTg0YWY0MWU0ZjA5MDc3N2VmMzBkNGQyNGIyMDU2OWNkNDdhMGFkMDBhNTUxYjg4MzQ1MzMiLCAnCiAgICAgICAgICAgICAgICAgICAnIkhhaXJwaW5Nb2RlIjogZmFsc2UsICJMaW5rTG9jYWxJUHY2QWRkcmVzcyI6ICIiLCAnCiAgICAgICAgICAgICAgICAgICAnIkxpbmtMb2NhbElQdjZQcmVmaXhMZW4iOiAwLCAiUG9ydHMiOiB7fSwgIlNhbmRib3hLZXkiOiAnCiAgICAgICAgICAgICAgICAgICAnIi92YXIvcnVuL2RvY2tlci9uZXRucy84OWQzOTZmMzkwMjkiLCAnCiAgICAgICAgICAgICAgICAgICAnIlNlY29uZGFyeUlQQWRkcmVzc2VzIjogbnVsbCwgIlNlY29uZGFyeUlQdjZBZGRyZXNzZXMiOiAnCiAgICAgICAgICAgICAgICAgICAnbnVsbCwgIkVuZHBvaW50SUQiOiAnCiAgICAgICAgICAgICAgICAgICAnImNkNzIyNDZlN2MwNzNkMjQ4NWMyZTA2MmM1YWU5ZjczMWRkOTgwYTBmNTRhMzkxMmY3MzBkOTlmNjg2ZmQ2ZTUiLCAnCiAgICAgICAgICAgICAgICAgICAnIkdhdGV3YXkiOiAiMTcyLjE3LjAuMSIsICJHbG9iYWxJUHY2QWRkcmVzcyI6ICIiLCAnCiAgICAgICAgICAgICAgICAgICAnIkdsb2JhbElQdjZQcmVmaXhMZW4iOiAwLCAiSVBBZGRyZXNzIjogIjE3Mi4xNy4wLjYiLCAnCiAgICAgICAgICAgICAgICAgICAnIklQUHJlZml4TGVuIjogMTYsICJJUHY2R2F0ZXdheSI6ICIiLCAiTWFjQWRkcmVzcyI6ICcKICAgICAgICAgICAgICAgICAgICciMDI6NDI6YWM6MTE6MDA6MDYiLCAiTmV0d29ya3MiOiB7ImJyaWRnZSI6IHsiSVBBTUNvbmZpZyI6ICcKICAgICAgICAgICAgICAgICAgICdudWxsLCAiTGlua3MiOiBudWxsLCAiQWxpYXNlcyI6IG51bGwsICJOZXR3b3JrSUQiOiAnCiAgICAgICAgICAgICAgICAgICAnIjcwMzVlNDhjOTI4NDUzYmI3NDJjODIwY2Q1MTcyOGFjMWY4NGNjNjg5YzhlZTFmY2I3M2NmMmM1N2YwNzVkNzYiLCAnCiAgICAgICAgICAgICAgICAgICAnIkVuZHBvaW50SUQiOiAnCiAgICAgICAgICAgICAgICAgICAnImNkNzIyNDZlN2MwNzNkMjQ4NWMyZTA2MmM1YWU5ZjczMWRkOTgwYTBmNTRhMzkxMmY3MzBkOTlmNjg2ZmQ2ZTUiLCAnCiAgICAgICAgICAgICAgICAgICAnIkdhdGV3YXkiOiAiMTcyLjE3LjAuMSIsICJJUEFkZHJlc3MiOiAiMTcyLjE3LjAuNiIsICcKICAgICAgICAgICAgICAgICAgICciSVBQcmVmaXhMZW4iOiAxNiwgIklQdjZHYXRld2F5IjogIiIsICJHbG9iYWxJUHY2QWRkcmVzcyI6ICcKICAgICAgICAgICAgICAgICAgICciIiwgIkdsb2JhbElQdjZQcmVmaXhMZW4iOiAwLCAiTWFjQWRkcmVzcyI6ICcKICAgICAgICAgICAgICAgICAgICciMDI6NDI6YWM6MTE6MDA6MDYiLCAiRHJpdmVyT3B0cyI6IG51bGx9fX0nXSwKICAgICAgICAgICAgICAgICAgWydAZG9ja2VyX3ZlcnNpb25faW5mbycsCiAgICAgICAgICAgICAgICAgICAneyJQbHVnaW5WZXJzaW9uIjogIjAuMSIsICJEb2NrZXJQeVZlcnNpb24iOiAiNC4xLjAiLCAnCiAgICAgICAgICAgICAgICAgICAnIkFwaVZlcnNpb24iOiAiMS40MSJ9J10sCiAgICAgICAgICAgICAgICAgIFsneyJCcmlkZ2UiOiAiIiwgIlNhbmRib3hJRCI6ICcKICAgICAgICAgICAgICAgICAgICciN2E5ZGJmMjJhY2I4NTcwNTVmNDg1ZTcxMjdiZjVkNjczYTBkMDQ3MzE0ODAyMjdmMGEwM2M3NzViNTFiZmNkZiIsICcKICAgICAgICAgICAgICAgICAgICciSGFpcnBpbk1vZGUiOiBmYWxzZSwgIkxpbmtMb2NhbElQdjZBZGRyZXNzIjogIiIsICcKICAgICAgICAgICAgICAgICAgICciTGlua0xvY2FsSVB2NlByZWZpeExlbiI6IDAsICJQb3J0cyI6IHt9LCAiU2FuZGJveEtleSI6ICcKICAgICAgICAgICAgICAgICAgICciL3Zhci9ydW4vZG9ja2VyL25ldG5zLzdhOWRiZjIyYWNiOCIsICcKICAgICAgICAgICAgICAgICAgICciU2Vjb25kYXJ5SVBBZGRyZXNzZXMiOiBudWxsLCAiU2Vjb25kYXJ5SVB2NkFkZHJlc3NlcyI6ICcKICAgICAgICAgICAgICAgICAgICdudWxsLCAiRW5kcG9pbnRJRCI6ICcKICAgICAgICAgICAgICAgICAgICciNTRlMGQ4MGE0OTA2ZGYxODAxYWE3NWJiMjZlMThiMTg1OWZlZmM4MWU2NGFhOTRmNzIxNTQ1YTE2YjdkMmIwMiIsICcKICAgICAgICAgICAgICAgICAgICciR2F0ZXdheSI6ICIxNzIuMTcuMC4xIiwgIkdsb2JhbElQdjZBZGRyZXNzIjogIiIsICcKICAgICAgICAgICAgICAgICAgICciR2xvYmFsSVB2NlByZWZpeExlbiI6IDAsICJJUEFkZHJlc3MiOiAiMTcyLjE3LjAuNCIsICcKICAgICAgICAgICAgICAgICAgICciSVBQcmVmaXhMZW4iOiAxNiwgIklQdjZHYXRld2F5IjogIiIsICJNYWNBZGRyZXNzIjogJwogICAgICAgICAgICAgICAgICAgJyIwMjo0MjphYzoxMTowMDowNCIsICJOZXR3b3JrcyI6IHsiYnJpZGdlIjogeyJJUEFNQ29uZmlnIjogJwogICAgICAgICAgICAgICAgICAgJ251bGwsICJMaW5rcyI6IG51bGwsICJBbGlhc2VzIjogbnVsbCwgIk5ldHdvcmtJRCI6ICcKICAgICAgICAgICAgICAgICAgICciN2U4ZTA2MTk4ZjlmZGFlNGVkODU1OTBlYTJiM2U0OWFkMzA1MDk3N2RhYWUwMTk3NDcyMDgzYTZlMjA1NDRiZCIsICcKICAgICAgICAgICAgICAgICAgICciRW5kcG9pbnRJRCI6ICcKICAgICAgICAgICAgICAgICAgICciNTRlMGQ4MGE0OTA2ZGYxODAxYWE3NWJiMjZlMThiMTg1OWZlZmM4MWU2NGFhOTRmNzIxNTQ1YTE2YjdkMmIwMiIsICcKICAgICAgICAgICAgICAgICAgICciR2F0ZXdheSI6ICIxNzIuMTcuMC4xIiwgIklQQWRkcmVzcyI6ICIxNzIuMTcuMC40IiwgJwogICAgICAgICAgICAgICAgICAgJyJJUFByZWZpeExlbiI6IDE2LCAiSVB2NkdhdGV3YXkiOiAiIiwgIkdsb2JhbElQdjZBZGRyZXNzIjogJwogICAgICAgICAgICAgICAgICAgJyIiLCAiR2xvYmFsSVB2NlByZWZpeExlbiI6IDAsICJNYWNBZGRyZXNzIjogJwogICAgICAgICAgICAgICAgICAgJyIwMjo0MjphYzoxMTowMDowNCIsICJEcml2ZXJPcHRzIjogbnVsbH19fSddXSwKICd2ZXJzaW9uJzogeydBcGlWZXJzaW9uJzogJzEuNDEnLAogICAgICAgICAgICAgJ0RvY2tlclB5VmVyc2lvbic6ICc0LjEuMCcsCiAgICAgICAgICAgICAnUGx1Z2luVmVyc2lvbic6ICcwLjEnfX0=", "details": {"argv": ["/omd/sites/lyo2/bin/cmk", "--debug", "-vvII", "rancid_nexus"], "env": {"SHELL": "/bin/bash", "OMD_ROOT": "/omd/sites/lyo2", "HISTCONTROL": "", "NAGIOS_PLUGIN_STATE_DIRECTORY": "/omd/sites/lyo2/var/monitoring-plugins", "HISTSIZE": "10000", "HISTTIMEFORMAT": "%d/%m/%y %T ", "PWD": "/omd/sites/lyo2", "LOGNAME": "lyo2", "MANPATH": "/omd/sites/lyo2/share/man::/opt/puppetlabs/puppet/share/man", "TEMPDIR": "/tmp/user/998", "MODULEBUILDRC": "/omd/sites/lyo2/.modulebuildrc", "HOME": "/omd/sites/lyo2", "LANG": "C.UTF-8", "HISTFILE": "/omd/sites/lyo2/.bash_history", "TMPDIR": "/tmp/user/998", "PROMPT_COMMAND": "history -a", "PERL5LIB": "/omd/sites/lyo2/local/lib/perl5/lib/perl5:/omd/sites/lyo2/lib/perl5/lib/perl5:", "OMD_SITE": "lyo2", "TERM": "xterm-256color", "USER": "lyo2", "TEMP": "/tmp/user/998", "PERL_MM_OPT": "INSTALL_BASE=/omd/sites/lyo2/local/lib/perl5/", "SHLVL": "1", "LD_LIBRARY_PATH": "/omd/sites/lyo2/local/lib:/omd/sites/lyo2/lib", "REQUESTS_CA_BUNDLE": "/omd/sites/lyo2/var/ssl/ca-certificates.crt", "LC_ALL": "C.UTF-8", "TMOUT": "14400", "TMP": "/tmp/user/998", "PATH": "/omd/sites/lyo2/lib/perl5/bin:/omd/sites/lyo2/local/bin:/omd/sites/lyo2/bin:/omd/sites/lyo2/local/lib/perl5/bin:/usr/local/bin:/usr/bin:/bin:/opt/puppetlabs/bin", "HISTIGNORE": "", "MP_STATE_DIRECTORY": "/omd/sites/lyo2/var/monitoring-plugins", "HISTFILESIZE": "999999", "MAIL": "/var/mail/lyo2", "MAILRC": "/omd/sites/lyo2/etc/mail.rc", "_": "/omd/sites/lyo2/bin/cmk"}}}
I think the problem is there, but I haven’t found anything about how to fix it.
Thanks,
Mick
