Check_MK Sessions Disconected monitoring
CMK version: 2.0
OS version: Centos7
I would like to know if i can monitor when the sessions stay active as DISCONECTED on windows servers:
i see this information but i dont knot what is the cmk.ini
The help text references the old config file not the actual yaml config.
Inside the “check_mk.user.yml” the winperf section should look like this to get the session counters.
winperf:
    counters:
        - Terminal Services: ts_sessions
Hi @andreas-doehler
Thank you for the responce, this is related to this configuration on the yml config file ?
The message means that you had before there the ts sessions check active or you configured this check as enforced service and the agent don’t provide data for this check.
Hi @andreas-doehler
Thank you, i can make the configuration, now is working, but for some reason i lost other checks:
Interfaces and CPU Utilization
With this configuration, could you please review my configuration to see why i lost these other two checks?
Regards
The posted config is not from the “check_mk.user.yml”. Please don’t edit any yml file inside "C:\Program Files (x86)\checkmk\service".
Only the files inside "C:\ProgramData\checkmk\agent" should be altered.
Inside the “check_mk.user.yml” you have only have to add the three lines from my example.
Thank you for the observation @andreas-doehler!
