I’ve encountered an ongoing issue with our DB checks where the check_mysql_health consistently displays a “WARN” state. Upon attempting to execute the check manually on the server, located at /opt/omd/sites/prod/local/lib/nagios/plugins, I received the following response:
This looks like a version mismatch between the Perl module used for the build of the check and the now available one.
Can you please rebuild the check_mysql_health plugin from the source?
Such a problem can happen if you upgraded your OS after build of the plugin.
Thank you very Andreas for getting back on this, really appreciate it. That’s correct, there’s been an OS update recently. Would you happen to know where can I download or rebuild the check_mysql_health plugin?
